Stepper Motor Setup Trouble Shooting CNC Shield V3.0 - AccelStepper.h
ups ! my fault. setMinPulseWidth is a - you could call it a "member"-function of accelstepper.
So the correct syntax is:
stepper_y.setMinPulseWidth(200);
For convenience the complete code
#include <AccelStepper.h>
#define step_x 2
#define step_y 3
#define step_z 4
#define dir_x 5
#define dir_y 6
#define dir_z 7
int led = 13;
// AccelStepper stepper_x(1, step_x, dir_x);
AccelStepper stepper_y(1, step_y, dir_y);
// AccelStepper stepper_z(1, step_z, dir_z);
  pinMode(led, OUTPUT);
  for (int n = 0; n < 5; n++)
    digitalWrite(led, HIGH);
    digitalWrite(led, LOW);
  stepper_y.setMaxSpeed(1000);
  stepper_y.setSpeed(100);
  stepper_y.runSpeed();
  delayMicroseconds(800);
  // delay(1);  // alternativey use a 1 millisecond delay
If you like to do more investigations on the accelStepper-problem
You could change the compile-log to maximum detail-output
like described in this tutorial.
Activating maximum details does help even in case that the code compiles
The thing I am most interested in is what version of the AccelStepper-library do you use?
best regards Stefan
Version 1.64
I finally took a Arduino-clone board and uploaded this code
#define step_x 2
#define step_y 3
#define step_z 4
#define dir_x 5
#define dir_y 6
#define dir_z 7
int led = 13;
  //stepper_y.setMinPulseWidth(200);
  //delayMicroseconds(800);
which is essentially your initial code except for added LED blinking in setup
and some comments but the same active code
On my Arduino-Clone board that has a QFP-package-chip instead of a DIL-housing
On this board your code runs and runs
Maybe there is a problem through code-optimisation
The compiler can be adjusted to different levels of code-optimisations that might cause this problem if your loop has just this single function-call
Your Arduino uno seems to be a QFP-chip clone too.
I looked up my storage and found an Arduino Uno-board with blue color that looks very similar to yours.
Having the same color does NOT mean it is the same manufacturer.
I tested the code from post # 23 too.
And this code runs well.
Another idea - but this is just a wild guessing - which could mean nothing
is to use a different IO-pin than IO-pin 3 for the step-pulses
So what results do you get if you run this code-version that uses IO-pin 4
Switch off all power-supplies !
Then disconnect the stepper-motor-driver from the Arduino
What happens if you run the code on the Arduino-Uno with everything disconnected
and just measure the frequency on IO-pin 4
#define step_y 4
#define dir_y 6
int led = 13;
  for (int n = 0; n < 5; n++) {
best regards Stefan
What happens if you use this code.
Step-pin is pin 4
and this code has an additional heartbeat-blinker that makes the onboard LED blink at 2 Hz.
Does the LED continue to blink even if you do not measure the 100 Hz step-pulse-frequency with your digital multimeter?
On my Arduino Uno the code runs and step-pulses are continually created
#define step_y 4
#define dir_y 6
int led = 13;
  BlinkHeartBeatLED(led,250);
// easy to use helper-function for non-blocking timing
boolean TimePeriodIsOver (unsigned long &startOfPeriod, unsigned long TimePeriod) {
  unsigned long currentMillis  = millis();
  if ( currentMillis - startOfPeriod >= TimePeriod ) {
    // more time than TimePeriod has elapsed since last time if-condition was true
    startOfPeriod = currentMillis; // a new period starts right here so set new starttime
    return true;
  else return false;            // actual TimePeriod is NOT yet over
unsigned long MyTestTimer = 0;                   // Timer-variables MUST be of type unsigned long
const byte    OnBoard_LED = 2;
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
  static unsigned long MyBlinkTimer;
  pinMode(IO_Pin, OUTPUT);
  if ( TimePeriodIsOver(MyBlinkTimer,BlinkPeriod) ) {
    digitalWrite(IO_Pin,!digitalRead(IO_Pin) );
best regards Stefan
Disconnected everything leaving the bare Uno board. Tested it using both IO 3 & 4 (one at a time) as the step output.
They created the 100Hz signal for no more than 10 seconds then dropped to 0Hz.
Interesting! I ran the heartbeat-blinker variant for half an hour and it didn't fall over. Produced the 100Hz signal the entire time. I set up a tripod to watch it :wink:
