This is a model railway project, moving a slider from side to side and aligning the tracks to depart locos.
I have a problem lining up my tracks but only in one direction.
I home my slider, then move the slider to position 1-1 which moves the slider from R-L.
Everything lines up.
I move the slider to position 1-2 which moves the slider from L-R and the tracks are about .5mm out.
I move the slider to position 1-3 L-R then back to position 1-2 R-L.
My problem is R to L OK.
L to R is .5mm out.
I am thinking it must be a mechanical problem as the position is programmed into the software.
Positioning is all done through software off a homing switch.
I cannot find any mechanical cure and was hoping there would be a software fix.
Would it be possible to move the slider L to R, say 3mm pass the track position then R to L back into position?
[code]
#include <Wire.h>
#include <Auto485.h>
#include <CMRI.h>
#include <AccelStepper.h>
#define dirPin 3 //A4988 Direction Pin
#define stepPin 4
//A4988 Step Pin
#define motorInterfaceType 1 // Define stepper motor connections and motor interface type. Motor interface type must be set to 1 when using a driver:
Auto485 bus(2); // Arduino pin 2 -> MAX485 DE and RE pins
CMRI cmri(6, 0, 192, bus); // Node setup
int endStop = 6; // Connect output to push button & end stop switch
int relayPin = 5; // SFY relay to change track polarity
int constexpr SFY_unobstructed_detector = 7; // All SLF IRD's connected to this pin
long initial_homing = -1; // Used to Home Stepper at startup
int value = 0;
int SFYclear = 8; //Connect to Nano7 Pin 3 to report back to JMRI that SFY is not obstructed
int SFYmoving = 9; //Connect to Nano7 pin 4 to report back to JMRI SFY is moving
AccelStepper stepper = AccelStepper(motorInterfaceType, stepPin, dirPin); //defines stepper setup
pinMode(relayPin, OUTPUT); // Set pin as output
digitalWrite(relayPin, HIGH); // Set initial state OFF for low trigger relay
pinMode(SFY_unobstructed_detector, INPUT); // IRD's Connected to this pin
pinMode (SFYclear, OUTPUT); // Set pin as output
digitalWrite (SFYclear, LOW); // Set initial state to off
pinMode(endStop, INPUT_PULLUP); // Endstop switch
pinMode (SFYmoving, OUTPUT); // Set pin as output
digitalWrite (SFYmoving, HIGH);
bus.begin(115200, SERIAL_8N2); // Open the RS485 bus at *****bps
// Home the SFY
stepper.setMaxSpeed(10000);
stepper.setAcceleration(14000);
while (digitalRead(endStop)) {
stepper.moveTo(initial_homing); // Read the state of endstop
initial_homing--; // Decrease by 1 for next move if needed
stepper.run(); // Start moving the stepper
while (!digitalRead(endStop)) { // Read the state of endstop
stepper.moveTo(initial_homing); // Make the Stepper move CW until the switch is deactivated
stepper.run();
initial_homing++;
stepper.setCurrentPosition(0); // End stop reached position zero
//stepper.runToNewPosition(3000); // Set this to move the SFY to a new starting position after homing complete
int position = 0; // Sets the position of Steppers to zero
Serial.println("Homing Completed");
int update_value_from_cmri(int original_value) // Define case numbers to correspond with CMRI bit numbers in JMRI
int static value_for_cmri_bit[] = { 11, 12, 13, 14, 15, 16, 17, //CMRI bit 6001-6007
21, 22, 23, 24, 25, 26, 27, 28, //CMRI bit 6008-6015
31, 32, 33, 34, 35, 36, 37, 38, 39, //CMRI bit 6016-6024
41, 42, 43, 44, 45, 46, 47, 48, 49, 410, //CMRI bit 6025-6034
51, 52, 53, 54, 55, 56, 57, 58, 59, 510, 511, 512, //CMRI bit 6035-6046
61, 62, 63, 64, 65, 66, 67, 68, 69, 610, 611, 612, 613, //CMRI bit 6047-6059
76, 77, 78, 79, 710, 711, 712, 713, 714, 715, 716, 717, 718, //CMRI bit 660-6072
89, 810, 811, 812, 813, 814, 815, 816, 817, 818, 819, 820, 821, //CMRI bit 6073-6085
912, 913, 914, 915, 916, 917, 918, 919, 920, 921, 922, 923, 924, //CMRI bit 6086-6098
1016, 1017, 1018, 1019, 1020, 1021, 1022, 1023, 1024, 1025, 1026, 1027, //CMRI bit 6099-6110
1118, 1119, 1120, 1121, 1122, 1123, 1124, 1125, 1126, 1127, 1128, 1129, //CMRI bit 6111-6122
1220, 1221, 1222, 1223, 1224, 1225, 1226, 1227, 1228, 1229, 1230, 1231, 1232, // CMRI bit 6123-6135
1324, 1325, 1326, 1327, 1328, 1329, 1330, 1331, 1332, //CMRI bit 6136-6144
1425, 1426, 1427, 1428, 1429, 1430, 1431, 1432, //CMRI bit 6145-6152
1526, 1527, 1528, 1529, 1530, 1531, 1532, //CMRI bit 6153-6159
1627, 1628, 1629, 1630, 1631, 1632, //CMRI bit 6160-6165
int constexpr number_of_cmri_bits =
sizeof(value_for_cmri_bit) / sizeof(value_for_cmri_bit[0]);
cmri.process();
for (int cmri_bit = 0; cmri_bit < number_of_cmri_bits; cmri_bit++)
if (cmri.get_bit(cmri_bit) == 1)
return value_for_cmri_bit[cmri_bit];
return original_value;
void move_stepper_to_position_for_value(int value) //Max49500 steps to reach SFY extent Min
switch (value)
case 11:
{stepper.runToNewPosition(24470); // When stepper is running it blocks all commands untill it has reached its new position.
digitalWrite (relayPin, LOW); // Turns relay off/on to change track polarity.
case 12:
{ stepper.runToNewPosition(28430);
digitalWrite (SFYmoving, LOW); // Set pin 9 low
case 13:
{ stepper.runToNewPosition(32360);
case 14:
{ stepper.runToNewPosition(36290);
case 15:
{ stepper.runToNewPosition(40220);
case 16:
{ stepper.runToNewPosition(44150);
case 17:
{ stepper.runToNewPosition(48080);
case 21:
{ stepper.runToNewPosition(20310);
case 22:
{ stepper.runToNewPosition(24240);
case 23:
{ stepper.runToNewPosition(28170);
case 24:
{ stepper.runToNewPosition(32100);
case 25:
{ stepper.runToNewPosition(36030);
case 26:
{ stepper.runToNewPosition(39960);
case 27:
{ stepper.runToNewPosition(43890);
case 28:
{ stepper.runToNewPosition(47820);
case 31:
{ stepper.runToNewPosition(16290);
case 32:
{ stepper.runToNewPosition(20220);
case 33:
{ stepper.runToNewPosition(24150);
case 34:
{ stepper.runToNewPosition(28080);
case 35:
{ stepper.runToNewPosition(32030);
case 36:
{ stepper.runToNewPosition(35960);
case 37:
{ stepper.runToNewPosition(39890);
case 38:
{ stepper.runToNewPosition(43800);
case 39:
{ stepper.runToNewPosition(47690);
case 41:
{ stepper.runToNewPosition(10890);
case 42:
{ stepper.runToNewPosition(14780);
case 43:
{ stepper.runToNewPosition(18710);
case 44:
{ stepper.runToNewPosition(22640);
case 45:
{ stepper.runToNewPosition(26570);
case 46:
{ stepper.runToNewPosition(30500);
case 47:
{ stepper.runToNewPosition(34430);
case 48:
{ stepper.runToNewPosition(38360);
case 49:
{ stepper.runToNewPosition(42290);
case 410:
{ stepper.runToNewPosition(46220);
case 51:
{ stepper.runToNewPosition(5090);
case 52:
{ stepper.runToNewPosition(9060);
case 53:
{ stepper.runToNewPosition(12990);
case 54:
{ stepper.runToNewPosition(16940);
case 55:
{ stepper.runToNewPosition(20850);
case 56:
{ stepper.runToNewPosition(24780);
case 57:
{ stepper.runToNewPosition(28700);
case 58:
{ stepper.runToNewPosition(32630);
case 59:
{ stepper.runToNewPosition(36540);
case 510:
{ stepper.runToNewPosition(40485);
case 511:
{ stepper.runToNewPosition(44410);
case 512:
{ stepper.runToNewPosition(48340);
case 61:
{ stepper.runToNewPosition(930);
case 62:
{ stepper.runToNewPosition(4860);
case 63:
{ stepper.runToNewPosition(8790);
case 64:
{ stepper.runToNewPosition(12720);
case 65:
{ stepper.runToNewPosition(16650);
case 66:
{ stepper.runToNewPosition(20580);
case 67:
{ stepper.runToNewPosition(24510);
case 68:
{ stepper.runToNewPosition(28440);
case 69:
{ stepper.runToNewPosition(32370);
case 610:
{ stepper.runToNewPosition(36320);
case 611:
{ stepper.runToNewPosition(40230);
case 612:
{ stepper.runToNewPosition(44160);
case 613:
{ stepper.runToNewPosition(48090);
case 76:
{ stepper.runToNewPosition(1090);
digitalWrite (relayPin, HIGH);
case 77:
{ stepper.runToNewPosition(5020);
case 78:
{ stepper.runToNewPosition(8950);
case 79:
{ stepper.runToNewPosition(12880);
case 710:
{ stepper.runToNewPosition(16790);
case 711:
{ stepper.runToNewPosition(20740);
case 712:
{ stepper.runToNewPosition(24640);
case 713:
{ stepper.runToNewPosition(28540);
case 714:
{ stepper.runToNewPosition(32470);
case 715:
{ stepper.runToNewPosition(36400);
case 716:
{ stepper.runToNewPosition(40330);
case 717:
{ stepper.runToNewPosition(44260);
case 718:
{ stepper.runToNewPosition(48190);
case 89:
{ stepper.runToNewPosition(1810);
case 810:
{ stepper.runToNewPosition(5740);
case 811:
{ stepper.runToNewPosition(9670);
case 812:
{ stepper.runToNewPosition(13600);
case 813:
{ stepper.runToNewPosition(17530);
case 814:
{ stepper.runToNewPosition(21460);
case 815:
{ stepper.runToNewPosition(25390);
case 816:
{ stepper.runToNewPosition(29320);
case 817:
{ stepper.runToNewPosition(33250);
case 818:
{ stepper.runToNewPosition(37180);
case 819:
{ stepper.runToNewPosition(41110);
case 820:
{ stepper.runToNewPosition(45040);
case 821:
{ stepper.runToNewPosition(48970);
case 912:
{ stepper.runToNewPosition(890);
case 913:
{ stepper.runToNewPosition(4820);
case 914:
{ stepper.runToNewPosition(8750);
case 915:
{ stepper.runToNewPosition(12680);
case 916:
{ stepper.runToNewPosition(16610);
case 917:
{ stepper.runToNewPosition(20540);
case 918:
{ stepper.runToNewPosition(24470);
case 919:
{ stepper.runToNewPosition(28400);
case 920:
{ stepper.runToNewPosition(32330);
case 921:
{ stepper.runToNewPosition(36260);
case 922:
{ stepper.runToNewPosition(40190);
case 923:
{ stepper.runToNewPosition(44120);
case 924:
{ stepper.runToNewPosition(48050);
case 1016:
{ stepper.runToNewPosition(2890);
case 1017:
{ stepper.runToNewPosition(6860);
case 1018:
{ stepper.runToNewPosition(10780);
case 1019:
{ stepper.runToNewPosition(14710);
case 1020:
{ stepper.runToNewPosition(18640);
case 1021:
{ stepper.runToNewPosition(22570);
case 1022:
{ stepper.runToNewPosition(26500);
case 1023:
{ stepper.runToNewPosition(30430);
case 1024:
{ stepper.runToNewPosition(34360);
case 1025:
{ stepper.runToNewPosition(38290);
case 1026:
{ stepper.runToNewPosition(42220);
case 1027:
{ stepper.runToNewPosition(46150);
case 1118:
{ stepper.runToNewPosition(1850);
case 1119:
{ stepper.runToNewPosition(5780);
case 1120:
{ stepper.runToNewPosition(9710);
case 1121:
{ stepper.runToNewPosition(13620);
case 1122:
{ stepper.runToNewPosition(17570);
case 1123:
{ stepper.runToNewPosition(21500);
case 1124:
{ stepper.runToNewPosition(25430);
case 1125:
{ stepper.runToNewPosition(29360);
case 1126:
{ stepper.runToNewPosition(33290);
case 1127:
{ stepper.runToNewPosition(37220);
case 1128:
{ stepper.runToNewPosition(41150);
case 1129:
// case 1220:
// { stepper.runToNewPosition(2222);//Not used
// break;
case 1221:
{ stepper.runToNewPosition(3818);
case 1222:
{ stepper.runToNewPosition(7748);
case 1223:
{ stepper.runToNewPosition(11678);
case 1224:
{ stepper.runToNewPosition(15608);
case 1225:
{ stepper.runToNewPosition(19538);
case 1226:
{ stepper.runToNewPosition(23468);
case 1227:
{ stepper.runToNewPosition(27398);
case 1228:
{ stepper.runToNewPosition(31328);
case 1229:
{ stepper.runToNewPosition(35258);
case 1230:
{ stepper.runToNewPosition(39188);
case 1231:
{ stepper.runToNewPosition(43118);
case 1232:
{ stepper.runToNewPosition(47048);
case 1324:
{ stepper.runToNewPosition(2180);
case 1325:
{ stepper.runToNewPosition(6070);
case 1326:
{ stepper.runToNewPosition(10000);
case 1327:
{ stepper.runToNewPosition(13930);
case 1328:
{ stepper.runToNewPosition(17860);
case 1329:
{ stepper.runToNewPosition(21790);
case 1330:
{ stepper.runToNewPosition(25720);
case 1331:
{ stepper.runToNewPosition(29650);
case 1332:
{ stepper.runToNewPosition(33580);
case 1425:
{ stepper.runToNewPosition(1880);
case 1426:
{ stepper.runToNewPosition(5810);
case 1427:
{ stepper.runToNewPosition(9740);
case 1428:
{ stepper.runToNewPosition(13670);
case 1429:
{ stepper.runToNewPosition(17600);
case 1430:
{ stepper.runToNewPosition(21530);
case 1431:
{ stepper.runToNewPosition(25460);
case 1432:
{ stepper.runToNewPosition(29390);
case 1526:
{ stepper.runToNewPosition(1460);
case 1527:
{ stepper.runToNewPosition(5390);
case 1528:
{ stepper.runToNewPosition(9320);
case 1529:
{ stepper.runToNewPosition(13250);
case 1530:
{ stepper.runToNewPosition(17180);
case 1531:
{ stepper.runToNewPosition(21110);
case 1532:
{ stepper.runToNewPosition(25040);
case 1627:
{ stepper.runToNewPosition(1230);
case 1628:
{ stepper.runToNewPosition(5200);
case 1629:
{ stepper.runToNewPosition(9130);
case 1630:
{ stepper.runToNewPosition(13060);
case 1631:
{ stepper.runToNewPosition(16990);
case 1632:
{ stepper.runToNewPosition(20920);
// cmri.set_bit(0, !digitalRead(HIGH));
default:
Serial.print("Invalid position request: ");
Serial.println(value);
value = update_value_from_cmri(value);
if (value > 0)
if (LOW == digitalRead(SFY_unobstructed_detector))
digitalWrite (SFYmoving, HIGH); // Set pin 9 high and stays high untill stepper has moved into position
move_stepper_to_position_for_value(value);
digitalWrite (SFYclear, LOW); // Set sensor SFY Obstructed in panelPro to " SFY Clear"
Serial.println("Clear To Move");
digitalWrite (SFYclear, HIGH); // Set sensor SFY Obstructed in panelPro to " SFY Obstructed"
Serial.println("Obstruction");
[/code]
