Stepper motor speed control via blutooth
Hey chaps! I am currently working on a project. My aim is to controll a stepper motor via android blutooth. I am using the uno. The setup works well. I am able to start and stop the stepper via buttons on blutooth console on my phone by issuing commands suchave as f1,f2,f3…but what I would like to achieve is a slow gradual speed from min to max. Could someone please help with this code to implement this.
#include <AccelStepper.h> // Library created by Mike McCauley at http://www.airspayce.com/mikem/arduino/AccelStepper/
// AccelStepper Setup
AccelStepper stepper(1, 5, 6); // 1 = Easy Driver interface, Pin 4 connected to STEP pin of Easy Driver, Pin 5 connected to DIR pin of Easy Driver
#include <SoftwareSerial.h>
SoftwareSerial portOne(0, 1); // software serial #1: TX = digital pin 10, RX = digital pin 11
// Define our three input button pins
#define button1 3
#define button2 2
int spd = 8000; // The current speed in steps/second
int sign = 0; // Either 1, 0 or -1
stepper.setMaxSpeed(10000);
stepper.setSpeed(1000);
// Set up the three button inputs, with pullups
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
char c;
if(Serial.available()) {
c = Serial.read();
if (c == 'f') { // forward
sign = 1;
if (c == 'r') { // reverse
sign = -1;
if (c == 's') { // stop
sign = 0;
if (c == '1') { // super slow
spd = 10;
if (c == '2') { // slow
spd = 100;
if (c == '3') { // medium
spd = 300;
if (c == '4') { // fast
spd = 500;
if (c == '5') { // faster
spd = 8000;
if (c == '6') { // superfast
spd = 10000;
if (digitalRead(button1) == 0) {
sign = 1;
else if (digitalRead(button2) == 0) {
sign = -1;
stepper.setSpeed(sign * spd);
stepper.runSpeed();
As you might guess from its name the AccelStepper library is designed for acceleration.
You are using the command runSpeed() which does not use acceleration. Use the command run()
And I don't see any moveTo() command in your program - so how does the library know how far to move the motor?
...R
The stepper will run continuously untill a stop command is issued. I basically need to know how to add a command for 0-100% speed that can be controlled via a slider on android. The current code works fine for the defined speeds.
sternfox:
The AccelStepper library is not designed for that, and it is not the way stepper motors are normally used. Do you really need a stepper motor?
It would not be difficult to write your own code for that motor without using any library. Have a look at this Simple Stepper Code - especially the second example. For what you want you should probably check for a new command between every step.
I also posted a simple program using acceleration here
...R
Stepper Motor Basics
Yes need the stepper motor for the torque. I'm running a nema34 @8nm @60volts through a industrial cnc driver. I have seen a few projects that have variable speed control via bluetooth but no code examples available. I think I will add more speed increases to the code I posted and call each speed with the slider.
