Hello All,
This is the first time posting so forgive me. I am trying to code for a stepper motor using a driver. I cannot get the rpms anywhere close enough for what I need. I think I am doing it wrong in the coding. If someone can just take a look at my code and see if I am getting the highest rpms with the code I am using In the setup I have a Home move that is pretty straight forward using a micro switch. Then in loop I am moving the stepper in both directions with a pot to control the min /max speed.
Arduino Mega
DM542T driver
nema 23 stepper motor 1.8 deg 3.0 amp with brake
Here is my code
//stepper motor and driver controls
int pulse=6; //pulsing the stepper motor
int dir=8; //direction of stepper motor
int speed=1; // delay between pulses
int brake=A15; //stepper motor brake LOW=off HIGH
//control inputs
int airCyl=A11; // this controls the forward moving air cylinder HIGH=forward LOW=back
// Limit switches
int sw1=4; //home optical switch 0=not activated 1=activated
int sw2=5; //end optical switch
//varibles and macros
int steps=2; //used to set home pos after homing is completed
int potPin=A4; //analog pin for poteniometer for speed
int distance = 0;
int buttonState = 0;
int onOrOffState = 0;
int endLimit = 0;
//int start=10;
int speedCount = 100;
int goBack = 0;
//Define the pins Used
delay(5000);
pinMode(brake, OUTPUT); //sets A15 to output
pinMode(airCyl, OUTPUT);
pinMode(pulse, OUTPUT); //set pulse pin to output to stepper driver
pinMode(dir, OUTPUT); //set direction control to stepper driver
pinMode(sw1, INPUT_PULLUP); // Set home switch to input
pinMode(sw2, INPUT_PULLUP);//set end/limit switch to input
pinMode(10, INPUT_PULLUP);//start button
//Homing procedure for Motor
//Start moving up twoards the home switch
digitalWrite(brake, LOW);// turn stepper motor brake off
delay(10);
while (!digitalRead(sw1)) { //Do this until sw1 is activated
digitalWrite(dir, LOW); //HIGH=COunter Clockwise LOW=Clockwise
digitalWrite(pulse, HIGH); //start puling the motor
delay(speed); //sets the speed of the homing
digitalWrite(pulse, LOW);
delay(speed);
//Serial.println(pulse);
// Move off of home switch SW1
while (digitalRead(sw1)) { //do this untill sw1 is not activated
digitalWrite(dir, HIGH);
delayMicroseconds(1);
delay(1);
distance = 0; //Reset distance varible to 0
//Serial.println(onOrOffState); //debugging info should not be read
digitalWrite(brake, HIGH); //turn off stepper motor brake
}// end of set up
//Start button wait
buttonState = digitalRead(10);
if (buttonState == LOW) { //Low means button is pressed
onOrOffState = 1;
digitalWrite(brake, LOW);// Turn stepper motor brake off
digitalWrite(airCyl, LOW);//Move the platform forward
delay(5000);//Adjustable delay time for platform to move and heat up tube
// button push changes state and now motorl moves twoards end switch
while (onOrOffState == 1) {
//speed control
if(speedCount == 0) {
speed = analogRead(potPin); //analog adjust to speed of movement of platform
speed = map(speed,0, 1023, 25, 1);// 0-1023 arduino voltage maped to 25-1 pulse speed to motor
//Serial.println(speed);//debugging info
speedCount = 100;}//time delay for reading the analog read on speed poteniometer
delay(1);
distance = distance + 1;//start counting distance from home position
speedCount = speedCount - 1;//start counting for read on speed potinometer
//Serial.println(speedCount);//debugging info
Serial.println(distance);//debugging info
endLimit = digitalRead(5);//setting endlimit varible to pin 5 or sw2
if (digitalRead(sw2)) { //Do this until sw2 is activated
digitalWrite(airCyl, HIGH);//move platform back
//delay(10);
onOrOffState = 0;
goBack = 1;}
while(goBack == 1) {// move back the same amount of steps that it moved forward
delayMicroseconds(speed);
delay(1);
distance = distance - 1;// minus the distance
if (distance == 0) {//when distance hits 0 set goback varible to 0
goBack = 0;}
