Stepper Motor + TouchOSC
Hello
I am trying to add new idea to my project which is controlling two stepper motors using the Iphone
Stepper Motor EMG30 (EMG30 data)
with the motor driver MD25 (MD25 Technical Documentation)
I want to use the interfacing program TouchOSC (TouchOSC | hexler.net) with my arduino program using the Iphone to control the the two motors.
I searched in the internet and I found that the processing program (http://processing.org/) should be used but I don't know how to use it
This is the arduino code for the two motors :
*                    Arduino MD25 example code                  *
*                   MD25 running in serial mode                 *
*                     by James Henderson 2012                   *
#include <SoftwareSerial.h>
// Values of 0 being sent using serial.write() have to be cast as a byte to stop them being misinterpereted as NULL
// This is a bug with arduino 1
#define CMD                 (byte)0x00              //  MD25 command byte of 0
#define WRITESP1            0x31                    // Byte writes speed to motor 1
#define WRITEACCEL          0x33                    // Byte writes a value of acceleration
#define RESETREG            0x35                    // Byte resets encoders
#define SETMODE             0x34                    // Byte sets mode
#define READIVS             0x2C                    // Byte reads motor currents and battery voltage
#define READENCS            0x25                    // Byte reads both encoders
#define GET_VER             0x29
#define LCD_RX              0x02                    // RX and TX pins used for LCD0303 serial port
#define LCD_TX              0x03
#define LCD03_HIDE_CUR      0x04
#define LCD03_CLEAR         0x0C
#define LCD03_SET_CUR       0x02
long encValue = 0;
void setup(){
  Serial.write(CMD);                                            // Set MD25 accelleration value
  Serial.write(WRITEACCEL);
  Serial.write(10);
  delayMicroseconds(10);                                        // Wait for this to be processed
  Serial.write(CMD);                                            // Reset the encoder registers to 0
  Serial.write(RESETREG);
  Serial.write(CMD);                                            // Set mode to 2, Both motors controlled by writing to speed 1
  Serial.write(SETMODE);
  Serial.write(2);
                                   // Hide the LCD03 cursor
void loop(){
  while(encValue < 3000){               // While encoder 1 value less than 3000 move forward
    Serial.write(CMD);                  // Set motors to drive forward at full speed
    Serial.write(WRITESP1);
    Serial.write(150);
    encValue = readEncoder();
  delay(100);
  while(encValue > 100){
    Serial.write(CMD);                  // Drive motors reverse at full speed
    Serial.write(100);
  delay(100);
long readEncoder(){                        // Function to read and display the value of both encoders, returns value of first encoder
  long result1 = 0;
  long result2 = 0;
  Serial.write(CMD);
  Serial.write(READENCS);
  while(Serial.available() < 8){}          // Wait for 8 bytes, first 4 encoder 1 values second 4 encoder 2 values
  result1 = Serial.read();                 // First byte for encoder 1, HH.
  result1 <<= 8;
  result1 += Serial.read();                // Second byte for encoder 1, HL
  result1 <<= 8;
  result1 += Serial.read();                // Third byte for encoder 1, LH
  result1 <<= 8;
  result1  += Serial.read();               // Fourth byte for encoder 1, LL
  result2 = Serial.read();
  result2 <<= 8;
  result2 += Serial.read();
  result2 <<= 8;
  result2 <<= 8;
Could somebody help me with the processing code to control the motors with TouchOSC ?
Thanks in advance
Should be used where? You aren't trying to get your phone to talk to your PC are you? If you are, then using Processing would be useful.
Get what you want from the TouchOSC messages, in Processing, and send information to the Arduino via the serial port.
