Stepper motor turns one way only when i use stepper_oneRevolution example
I am new to arduino and stepper motor. İn order to learn how to use these I bought and arduino uno and a 28 BYJ-48 stepper motor. When I use code here "Robjax.com source code for YouTube Videos", I can make the motor turn either way non-stop but when I use the bottom code it does not stop after 3 seconds. And when I use example "stepper_oneRevolution" in the arduino program, it just turns cw non stop again. Why do I get these problems.
And one more thing, is there a good source to learn how to control stepper motor (learning the coding especially). I googled but found nothing good. I know some c++ but it avails nothing really.
Some info on those motors here:
http://arduino-info.wikispaces.com/SmallSteppers
Several well-tested example sketches are there..
Make sure the motor connections are correct.
Thanks for the site. Checked the cables multiple time, all are correct.
compnaion:
Post the program that is causing the problem so we can see what you can see.
...R
//original source is http://www.geeetech.com/wiki/index.php/Stepper_Motor_5V_4-Phase_5-Wire_%26_ULN2003_Driver_Board_for_Arduino
// This code is used with a video tutorial for RoboJax.com
// Published on March 27, 2017 from Aajx, ON, Canada.
// Updated on October 04, 2017 in Ajax, Ontrio, Canada for Robojax.com by Nejrabi
//If you want to run the motor up to certain time and then stop it, then this code will do that.
Just change the “runtime” value to any value in meli second. For 3 second enter 3000, for 5.5 second enter 5500
int Pin1 = 10;
int Pin2 = 11;
int Pin3 = 12;
int Pin4 = 13;
int _step = 0;
boolean dir = true;// false=clockwise, true=counter clockwise
int count=0;// counter for running time
int runTime = 3000;// the time motor will run
pinMode(Pin1, OUTPUT);
pinMode(Pin2, OUTPUT);
pinMode(Pin4, OUTPUT);
switch(_step){
case 0:
if(count <runTime)
digitalWrite(Pin1, LOW);
digitalWrite(Pin2, LOW);
digitalWrite(Pin3, LOW);
digitalWrite(Pin4, HIGH);
}else{
stop_motor();
case 1:
if(count <runTime)
digitalWrite(Pin3, HIGH);
}else{
stop_motor();
case 2:
if(count <runTime)
digitalWrite(Pin4, LOW);
}else{
stop_motor();
case 3:
if(count <runTime)
digitalWrite(Pin2, HIGH);
}else{
stop_motor();
case 4:
if(count <runTime)
}else{
stop_motor();
case 5:
if(count <runTime)
digitalWrite(Pin1, HIGH);
}else{
stop_motor();
case 6:
if(count <runTime)
}else{
stop_motor();
case 7:
if(count <runTime)
}else{
stop_motor();
default:
stop_motor();// stop the motor
if(dir){
_step++;
}else{
_step–;
if(_step>7){
_step=0;
if(_step<0){
_step=7;
delay(1);
// check if the counter has reached run time
if(count < runTime){
count++;//increment count
}else{
count =0;// set to zero
}// loop end
// this subroutine stops the motor
void stop_motor(){
This is the program I was talking about
To make it easier for people to help you please modify your post and use the code button </> so your code looks like this and is easy to copy to a text editor. See How to use the Forum
Your code is too long for me to study quickly without copying to a text editor.
…R
