Stepper motor using easydriver with AccelStepper behaviour
I'm using a 4 wire bipolar stepper with easy driver using step/dir/MS1/MS2 as pins 2,3,4,5 respectively.
Using the easy driver code I can successfully perform half step rotations.
When using the AccelStepper library and code that causes the motor to go in forward and then in reverse for a few seconds using FULL4WIRE and HALF4WIRE causes the motor to not reverse when expected and continues to spin in one direction
AccelStepper stepper(AccelStepper::FULL4WIRE, 2, 3,4,5)
AccelStepper stepper(AccelStepper::HALF4WIRE, 2, 3,4,5)
Using DRIVER or FULL2WIRE works as expected in terms of forward/reverse of the stepper although FULL2WIRE behaves like a half-step.
AccelStepper stepper(AccelStepper::FULL2WIRE, 2, 3)
AccelStepper stepper(AccelStepper::DRIVER, 2, 3)
stepper: https://www.sparkfun.com/datasheets/Robotics/SM-42BYG011-25.pdf
driver: Easy Driver Hook-up Guide - SparkFun Learn
The current documentation is unclear...
Does using DRIVER/FULL2DRIVER mean we can only using step/dir pins and not MS1/MS2 for half steps? is this a limitation of using the easydriver with AccelStepper library?
What is the difference between DRIVER and FULL2DRIVER?
If I want to use the MS1/MS2 for half steps how I can I use that using AccelStepper library if 4 wire stepper does not work with the FULL4/HALF4?
Does the Caution for blocking delay apply to all enumerators types or just DRIVER?
https://www.airspayce.com/mikem/arduino/AccelStepper/classAccelStepper.html#a3bc75bd6571b98a6177838ca81ac39ab
Number of pins to interface to. Integer values are supported, but it is preferred to use the MotorInterfaceType symbolic names. AccelStepper::DRIVER (1) means a stepper driver (with Step and Direction pins). If an enable line is also needed, call setEnablePin() after construction. You may also invert the pins using setPinsInverted(). Caution: DRIVER implements a blocking delay of minPulseWidth microseconds (default 1us) for each step. You can change this with setMinPulseWidth(). AccelStepper::FULL2WIRE (2) means a 2 wire stepper (2 pins required). AccelStepper::FULL3WIRE (3) means a 3 wire stepper, such as HDD spindle (3 pins required). AccelStepper::FULL4WIRE (4) means a 4 wire stepper (4 pins required). AccelStepper::HALF3WIRE (6) means a 3 wire half stepper, such as HDD spindle (3 pins required) AccelStepper::HALF4WIRE (8) means a 4 wire half stepper (4 pins required) Defaults to AccelStepper::FULL4WIRE (4) pins.
#include <AccelStepper.h>
// Define a stepper and the pins it will use
AccelStepper stepper(AccelStepper::DRIVER, 2, 3);
int pos = 3600;
  stepper.setMaxSpeed(3000);
  stepper.setAcceleration(1000);
  if (stepper.distanceToGo() == 0)
    pos = -pos;
    stepper.moveTo(pos);\
  stepper.run();
This is the correct setting for all drivers (like the Easydriver) that take step and direction signals
AFAIK the Easydriver defaults to microstepping. If you want either full steps or a different level of microstepping you need to connect the MS1 and MS2 connections to 5v or GND according to the table in the Sparkfun instructions
...R
Thank you for clarifying @Robin2.
