Hi All,
I'm in the process of making a CNC machine, I am using NEMA 17 stepper motors with EasyDriver boards to run them.
The problem I am facing is my stepper motor's rated voltage is 3.4 volts and the EasyDriver requires a minimum input of 7 volts for the motors.
What's really confusing me is there are lots of tutorials on how to hook up EasyDrivers to NEMA 17 motors and most of them use 12V inputs on the EasyDriver, but when you look at all the different types of of NEMA17 from RepRap's reference NEMA 17 Stepper motor - RepRap, hardly any of them are rated at 12V most are rated at 2-4 Volts.
My feeling is I am misinterpreting the meaning of "Rated Voltage" in this context, I mean the motors are pretty beefy size wise and 3.4 volts seems quite low for something this big.
Here is a link to my motor's spec http://www.ebay.co.uk/itm/CNC-Nema17-for-1-7A-3400g-cm-40mm-length-4-Lead-2-phase-Longs-Stepper-Motor-/280871522245?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item41653f4fc5
Here is a link to the EasyDriver boards I have http://www.ebay.co.uk/itm/EasyDriver-drive-stepper-motor-driver-board-/220922508583?pt=LH_DefaultDomain_0&hash=item337001f527
The sentence "EasyDriver-board voltage regulator chip can be set to 3.3V or 5V, directly with the 4-wire stepper motor and micro-controller and precisely control the stepper motor movement"
Implies it takes the input voltage (whatever that is) and supplies 3.3 or 5.5 volts to the motor, is that a correct interpretation ?
I would really appreciate if anyone can clarify exactly how many volts im supposed to supply to the easy driver boards whilst not frying my Motors!
All help appreciated.
