Hello guys,
Being new at the forum i have no idea if the topic is at the correct section, so if not, please move it at the correct one.
So let's talk about the problem that i am dealing with.
At first, I have a code that is making a comparison between two analog pins (in my case two Potentiometers) and transforming the analog inputs at two voltages which by comparison are moving a stepper motor clockwise and anti-clockwise. The code is working correctly until I execute the voltages at the LCD display. The display becomes blurry and the motor doesn't move even if the LEDs at the driver detect pulses. I am importing the code so anyone can tell me what is messed up with it.
Thanks in advance.
code :
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
int analogPin = A0; // POT 0
int analogPin1 = A1; // POT 1
int analogValue = 0; //
int analogValue1 = 0; //
float Rvoltage = analogValue * (5.0 / 1023.0); // CONSTANT VOLTAGE
float Vvoltage = analogValue1 * (5.0 / 1023.0); // VARIABLE VOLTAGE
int Pin1 = 8;//IN1 is connected to 8
int Pin2 = 9;//IN2 is connected to 9
int Pin3 = 10;//IN3 is connected to 10
int Pin4 = 11;//IN4 is connected to 11
int pole1[] ={0,0,0,0, 0,1,1,1,0};//pole1
int pole2[] ={0,0,0,1, 1,1,0,0,0};//pole2
int pole3[] ={0,1,1,1, 0,0,0,0,0};//pole3
int pole4[] ={1,1,0,0, 0,0,0,1,0};//pole4
int poleStep = 0; //
int dirStatus = 3;//
//INITIALIZE MOTOR PINS
pinMode(Pin1, OUTPUT); //DEFINING THE MOTOR PINS AS OUTPUT PINS
pinMode(Pin2, OUTPUT);
pinMode(Pin3, OUTPUT);
pinMode(Pin4, OUTPUT);
// INITIALIZE LCD
lcd.begin();
lcd.backlight();
lcd.clear();
lcd.setCursor (7,0);
lcd.print("WELCOME");
delay(2000);
lcd.setCursor (2,1);
lcd.print(" TO THE WORLD OF");
delay(2000);
lcd.setCursor (0,3);
lcd.print(" ARDUINO! ");
delay(5000);
void loop(){
analogValue = analogRead(analogPin); // READING VALUES
analogValue1 = analogRead(analogPin1); // READING VALUES
if (Rvoltage < Vvoltage)
poleStep++;
driveStepper(poleStep);
else if (Rvoltage > Vvoltage)
poleStep--;
driveStepper(8);
if (poleStep>7)
poleStep = 0;
else if (poleStep<0)
poleStep = 7;
delay(50);
lcd.clear();
lcd.setCursor (0,0);
lcd.print("Rvoltage : "); // print text
lcd.print(Rvoltage); //Showing voltage value
lcd.print("Vvoltage : "); // print text
void driveStepper(int c)
digitalWrite(Pin1, pole1
digitalWrite(Pin2, pole2[c]);
digitalWrite(Pin3, pole3[c]);
digitalWrite(Pin4, pole4[c]);
[for_arduino_forum.ino|attachment](upload://z0z0D87omh0nKfklIIdzsr1C4VE.ino) (2.33 KB)
