Stepper motor voltage
I salvage a PM35s-048 stepper motor from an old printer.
If I connect it directly to the arduino pins I canget it moving as it should but it's very weak.
according to the datasheet it should use 24V. I was wondering how I can supply it with this voltage (circuit-wise). I have a few transistors that can take the voltage and current, but I'mnot sure how to connect them (Or if I even need them).
You are also subjecting the arduino to more current that it can safly supply and so you are damaging the pins, please don't do this.
This is a bipolar motor
http://www.thebox.myzen.co.uk/Workshop/Motors_4.html
It needs driving with a circuit called a H-bridge, there are lots of them in chip form or you can make your own. You get the voltage from a power supply or batteries.
The specification for that motor says it is 24V, 5.5 ohms and needs a 600mA constant current driver. I would use one of these Pololu - A4988 Stepper Motor Driver Carrier to drive it, setting the current limit at 600mA or less. Alternatively, you can get low-cost A4988 stepper driver boards via eBay, but they mostly use a fixed resistor to set the current limit instead of a potentiometer, so you would have to change the resistor to reduce the current limit to 600mA.
