Stepper Motor wont turn in reverse
i am trying to make my stepper motor turn back to its start position when i hit a button. From what i have researched using the .step() command with a negative value should reverse it but it doesn’t. What am i doing wrong?
My code is a bit of a mess right now but here it is!
I put a comment on the line that should reverse it.
#include <Stepper.h>
#define STEPS 2048
Stepper stepper(STEPS, 10, 11, 12, 13);
int A = 2;
int B = 3;
int C = 4;
int D = 5;
int E = 6;
int F = 7;
int G = 8;
int H = 9; //pins for the 7 segment display
const int Plus = A4;
const int Minus = A3;
const int Clear = A2;
const int Enter = A1;
int buttonPushCounter = 0;
int PlusState = 0;
int lastPlusState = 0;
int MinusState = 0;
int lastMinusState = 0;
int ClearState = 0;
int lastClearState = 0;
int EnterState = 0;
int lastEnterState = 0;
int ServoVal = 0;
int ServoRotation = 0;
int NumZero(){
  digitalWrite(A, LOW);
  digitalWrite(B, HIGH);
  digitalWrite(C, HIGH);
  digitalWrite(D, HIGH);
  digitalWrite(E, LOW);
  digitalWrite(F, HIGH);
  digitalWrite(G, HIGH);
  digitalWrite(H, HIGH);
int NumOne(){
    digitalWrite(C, LOW);
    digitalWrite(D, LOW);
    digitalWrite(F, LOW);
    digitalWrite(G, LOW);
int NumTwo(){
  digitalWrite(B, LOW);
  digitalWrite(E, HIGH);
int NumThree(){
int NumFour(){
int NumFive(){
  digitalWrite(H, LOW);
int NumSix(){
int NumSeven(){
int NumEight(){
int NumNine(){
void setup(){
  pinMode(A, OUTPUT);
  pinMode(B, OUTPUT);
  pinMode(C, OUTPUT);
  pinMode(D, OUTPUT);
  pinMode(E, OUTPUT);
  pinMode(F, OUTPUT);
  pinMode(G, OUTPUT);
  pinMode(H, OUTPUT);
  pinMode(Plus, INPUT_PULLUP);
  pinMode(Minus, INPUT_PULLUP);
  pinMode(Clear, INPUT_PULLUP);
  pinMode(Enter, INPUT_PULLUP);
  NumZero();
  stepper.setSpeed(10);
void loop(){
  PlusState = digitalRead(Plus);
  MinusState = digitalRead(Minus);
  ClearState = digitalRead(Clear);
  EnterState = digitalRead(Enter);
  buttonPushCounter = constrain(buttonPushCounter, 0, 9);
  ServoVal = buttonPushCounter;
  if (PlusState != lastPlusState){
    if (PlusState == LOW){
      buttonPushCounter++;
    delay(100);
  lastPlusState = PlusState;
  if (MinusState != lastMinusState){
    if (MinusState == LOW){
      buttonPushCounter--;
    delay(100);
      lastMinusState = MinusState;
   if (ClearState != lastClearState){
    if (ClearState == LOW){
      stepper.step(-ServoRotation); //rotate stepper back to start position
    delay(100);
     lastClearState = ClearState;
  if (buttonPushCounter == 0){
    NumZero();
  else if (buttonPushCounter == 1){
    NumOne();
  else if (buttonPushCounter == 2){
    NumTwo();
  else if (buttonPushCounter == 3){
    NumThree();
  else if (buttonPushCounter == 4){
    NumFour();
  else if (buttonPushCounter == 5){
    NumFive();
  else if (buttonPushCounter == 6){
    NumSix();
  else if (buttonPushCounter == 7){
    NumSeven();
  else if (buttonPushCounter == 8){
    NumEight();
  else if (buttonPushCounter == 9){
    NumNine();
  ServoRotation = map(ServoVal, 0, 9, 0, 2048);
  if (EnterState == LOW){
  else if (EnterState == HIGH){
    stepper.step(0);
   Serial.println(ServoRotation);
Thanks!
Have you tried a very simple code where you say in the setup()
Set speed at 10 rpm
Execute 1024 steps (so should be half a turn - which should take 3 seconds at rpm=10)
then wait 5 seconds for the servo To get there and sit there
and then step -1024 to get back to start point
Keep the loop() empty
—> to see what happens?
