I have the boarduino on a breadboard, with a Stepper Motor Driver. The Stepper Motor Driver is the MC3479, and the specs on this driver are on this pdf:
The pins that are connected to my borduino are the CW/CCW pin and the Clk pin. I was hoping i could use the stepper library to control the motor, but that has not worked for me yet. I need help figuring out the code i need to write so that i can control the motor.
Thanks for the help
You don't need the stepping motor library with this chip, the chip creates the patterns of on and off the stepping motor needs. Without this chip the software needs to create the patterns and that's what the library does.
To move the motor just pulse the step line first high, then low with a digital write and if it is in a loop do a delay so the pulses are not too fast.
Yep that looks fine, maybe increase the delay a little.
I assume the rest of the pins of the chip set up, especially pin 6 (some value of resistor depending on the current you want to drive to ground) . Pins 8, 9 & 10 should be connected either to the Arduino (and set high or low) or to the appropriate logic level if you don't want to control them at the moment. And a 0.1uF capacitor from pin 16 to ground with pins 4,5,12 & 13 all connected to the arduino ground.
Is the motor just buzzing when it should be turning?
If it is, the step speed is too high.
The delay time (10) looks too small to me try increasing it as suggested above (maybe 30?).
