Hi, i have a unipolar stepper motor (STH-54D500, 1.3 A, 6.5 V) with 5 wires, without driver.
I know that if i want to connect it to an arduino uno card, i need an ULN2003A. But ULN2003 a has only 500 mA and my motor need 1.3A. What i can do/add to my system, and thank you.
Why can't you use the Arduino stepper library? This is the easiest way to do control it without a driver.
The ULN2003A is not strong enough for your motor, pick one that is stronger from the following list;
http://reprap.org/wiki/Stepper_motor_driver#Stepper_driver_chips
rcorr:
The ULN2003A is not strong enough for your motor, pick one that is stronger from the following list;http://reprap.org/wiki/Stepper_motor_driver#Stepper_driver_chips
Thanks for your list, but i found only bipolar stepper driver chips.
The Arduino microcontroller should probably replace the need for a driver chip.
Try the following code (file → examples → stepper → step_one_revolution)
Stepper Motor Control - one revolution
This program drives a unipolar or bipolar stepper motor.
The motor is attached to digital pins 8 - 11 of the Arduino.
The motor should revolve one revolution in one direction, then
one revolution in the other direction.
Created 11 Mar. 2007
Modified 30 Nov. 2009
by Tom Igoe
#include <Stepper.h>
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
// set the speed at 60 rpm:
myStepper.setSpeed(60);
// initialize the serial port:
// step one revolution in one direction:
Serial.println("clockwise");
myStepper.step(stepsPerRevolution);
// step one revolution in the other direction:
Serial.println("counterclockwise");
myStepper.step(-stepsPerRevolution);
If that doesn’t work due to voltage or amperage insuffiencies, I am unaware of any unipolar stepper drivers, so you would either have to make your own driver using transistors, or buy a motor shield for your Arduino. I recommend the Seeed motor shield V1.0 or 2.0.
cressmanj24:
Sorry. But this is BullCrap that wrong and could easily lead a newbie to damage his Arduino.
You cannot drive any motor directly with an Arduino.
@kdjender,
I have not heard of any other unipolar driver apart from the ULN2003 - Google might know.
I wonder is it possible to convert your 5-wire motor into a 6-wire motor. Some of the "unipolar" motors are bipolar motors in disguise. The 6-wire motors have 3 wires for each coil - one at each end and one in the centre. A unipolar motor has the 2 centre wires connected. For bipolar use one just ignores the centre wires of a 6-wire motor. However it is essential that the the two centre wires are separate.
...R
Sorry. I misunderstood the function of motor shield and driver, which led me to think that with a low power motor, only Arduino was necessary. Thank you for correcting me.
cressmanj24:
No problem. Everyone of us makes mistakes.
Best to limit advice to stuff you have actually done yourself.
...R
Here, this should be strong enough....
http://hades.mech.northwestern.edu/index.php/Unipolar_Stepper_Motor_Driver_Circuit
kdjender:
The ULN2803 has 8 channels, you can double them up for twice the current
handling. Otherwise its the same as ULN2003.
4 logic-level n-channel MOSFETs will perform better, but cost more.
