Stepper Motors not Getting Power
I mean check that everything is getting the right voltage between power and ground really - everything
is powered up. I presume that shield has a common ground.
Check each plugged-in A4988 is getting its supply on the relevant pins too (careful not to short anything
when probing).
Usually in a case like this there is one little detail wrong - so you have to be systematic, assume nothing,
check everything.
