*** I am using a HC-05 Bluetooth Module to connect the Arduino Bluetooth Controller Android App to my Arduino Uno Wifi R4. My bluetooth module can connect easily to my phone and also to the app. The stepper motors work FINE when they are NOT being handled by an external controller (my phone). Any advice?*** My code is attatched below.
// Stepper motor pins
const int stepPinX = 2;
const int dirPinX = 5;
const int stepPinY = 3;
const int dirPinY = 6;
const int stepDelay = 500; // microseconds
bool motorsEnabled = false;
// Motor pins
pinMode(stepPinX, OUTPUT);
pinMode(dirPinX, OUTPUT);
pinMode(stepPinY, OUTPUT);
pinMode(dirPinY, OUTPUT);
// Initial direction
digitalWrite(dirPinX, HIGH);
digitalWrite(dirPinY, HIGH);
// Start serial for Bluetooth communication
// Check for Bluetooth input
if (Serial.available()) {
char command = Serial.read();
if (command == 'START') {
motorsEnabled = true;
} else if (command == 'STOP') {
// Only step motors if enabled
if (motorsEnabled) {
digitalWrite(stepPinX, HIGH);
digitalWrite(stepPinY, HIGH);
delayMicroseconds(stepDelay);
digitalWrite(stepPinX, LOW);
digitalWrite(stepPinY, LOW);
First, I would recommend disabling the motors at the end of the setup() function, so that they remain disabled in case your loop() function is not controlling the motors (which is what is currently happening); for example, add the following after setting the initial direction values:
Second, to debug your Bluetooth commands, add the following statement inside the if(motorsEnabled) block in your loop() function, to allow you to check what is happening using the Serial Monitor in the IDE:
Serial.println("Motors enabled and stepping.");
Finally, because Serial communication can be unreliable when the connection is first made, I would suggest adding the following statement at the end of your setup() function, just after the Serial.begin(9600) statement:
Serial.println("Serial communication established.");
Serial.println("Motors disabled.");
Thank you. I implemented the suggestions in here including using the string.h library but my below code still causes the motors to twitch - any other suggestion would be beyond helpful.
#include <string.h> // Required for strcmp()
char commandBuffer[20]; // Buffer to store incoming command
byte bufferIndex = 0;
// Motor pins
// Read characters into buffer until newline
while (Serial.available()) {
char c = Serial.read();
if (c == '\n') {
commandBuffer[bufferIndex] = '\0'; // Null-terminate the string
// Compare commands
if (strcmp(commandBuffer, "START") == 0) {
} else if (strcmp(commandBuffer, "STOP") == 0) {
bufferIndex = 0; // Reset buffer for next command
if (bufferIndex < sizeof(commandBuffer) - 1) {
commandBuffer[bufferIndex++] = c;
