Stepper moves roughly (due to millis(), I think)
Hi folks,
I am almost done with my project (I will share with all of you when finished) but I am finding now some problems with my steppers.
I am using AccelStepper library and I think it is awesome. It is probably my fault, because of a dirty code, but I am running out of time and trial-error method can be too much time-consuming.
I am getting rough movement when using the loop, but not when using blocking queries (like runToNewPosition) so that way I can confirm that problem is not related to nor motors neither drivers.
// Copyright (c) 2016 Daniel Grau Gil-Díez - danielgraugildiez@gmail.com
// Based on a project of Stefano Guglielmetti
// https://github.com/amicojeko
// Permission is hereby granted, free of charge, to any person obtaining a
// copy of this software and associated documentation files (the "Software"),
// to deal in the Software without restriction, including without limitation
// the rights to use, copy, modify, merge, publish, distribute, sublicense,
// and/or sell copies of the Software, and to permit persons to whom the
// Software is furnished to do so, subject to the following conditions:
// The above copyright notice and this permission notice shall be included in
// all copies or substantial portions of the Software.
// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
// IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
// FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
// AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
// LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
// FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
// DEALINGS IN THE SOFTWARE.
// Include Bridge, Proccess and Stepper libraries
#include <Bridge.h>
#include <Process.h>
#include <AccelStepper.h>
// Declare variables, LEDs and Steppers (out of voids are declared global vars)
// Stepper definitions
AccelStepper stepper1(AccelStepper::DRIVER, 9, 8);
AccelStepper stepper2(AccelStepper::DRIVER, 11, 10);
AccelStepper stepper3(AccelStepper::DRIVER, 13, 12);
boolean stepperOneLaunched = false;
boolean stepperTwoLaunched = false;
boolean stepperThreeLaunched = false;
int mechanicalEnd = 1000;
int mechanicalEndPin1 = A0;
int mechanicalEndPin2 = A1;
int mechanicalValue1;
int mechanicalValue2;
// Miilis variables
unsigned long currentMillis;
unsigned long hashtagOneMillis = 0; // Long (32bits) positive variable for time management
unsigned long hashtagTwoMillis = 0; // Long (32bits) positive variable for time management
unsigned long hashtagThreeMillis = 0; // Long (32bits) positive variable for time management
const unsigned long delayInterval = 30000; // Time interval between stepper moves
const unsigned long delayDown = 15000; // Time interval until the stepper goes up
// Declare bo_buffer variable which gets values from 'go' bridge variable
char go_buffer[2];
// Initialize go variable
int  go = 0;
// Security reset counter to relaunch the script if fails.
int resetCount = 0;
// Initialize the Python Streaming script
Process p;
  // Hardware initialization
  // Initialize the serial port
  // Initialize the Bridge Library
  Bridge.begin();
  // Initialize Tweepy Streaming Script
  callTweepyStreaming();
  // Set steppers properties
  stepper1.setMaxSpeed(400.0);
  stepper1.setAcceleration(100.0);
  // Home position stepper 1 (PUT INTO A FUNCTION)
  stepper1.moveTo(3000);
  stepper1.setSpeed(-300);
  mechanicalValue1 = analogRead(mechanicalEndPin1);
  while (mechanicalValue1 > mechanicalEndPin1) {
    stepper1.runSpeed();
    Serial.print(mechanicalValue1);
  stepper1.stop();
  stepper1.setCurrentPosition(200);
  stepper1.move(200);
  stepper1.runToPosition();
  // Home position Stepper 2 (PUT INTO A FUNCTION)
  stepper2.setMaxSpeed(400.0);
  stepper2.setAcceleration(100.0);
  stepper2.moveTo(3000);
  stepper2.setSpeed(-300.0);
  mechanicalValue2 = analogRead(mechanicalEndPin2);
  while (mechanicalValue2 > mechanicalEndPin2) {
    stepper2.runSpeed();
    Serial.print(mechanicalValue2);
  stepper2.stop();
  stepper2.setCurrentPosition(200);
  stepper2.move(200);
  stepper2.runToPosition();
  // Home position Stepper 3 (PUT INTO A FUNCTION)
  stepper3.stop();
  stepper3.setMaxSpeed(400.0);
  stepper3.setAcceleration(400.0);
  stepper3.moveTo(5000);
  stepper3.setSpeed(300.0);
    stepper3.runSpeed();
  stepper3.stop();
  stepper3.setCurrentPosition(0);
  stepper3.move(-50);
  stepper3.runToPosition();
  // Always check if Python is running and we are not in an empty loop
  while (p.running() && (resetCount < 2000)) {
    // Read the "go" Bridge var and copies it into the go_buffer variable
    currentMillis = millis();
    Bridge.get("go", go_buffer, 2);
    //Serial.println("Entramos al loop");
    // Convert the bugger into an int variable
    go = atoi(go_buffer);
    //Serial.println(go);
    // Check for "go" var and go to respective function
    if ((go == 1) && ((unsigned long)(millis() - hashtagOneMillis >= delayInterval))) {
        hashtagOneMillis = currentMillis;
        stepperOneLaunched = true;
        stepper1.moveTo(200);
    } else if ((go == 2) && ((unsigned long)(millis() - hashtagTwoMillis >= delayInterval))) {
        hashtagTwoMillis = currentMillis;
        stepperTwoLaunched = true;
        stepper2.moveTo(200);
    } else if ((go == 3) && ((unsigned long)(millis() - hashtagThreeMillis >= delayInterval))) {
        hashtagThreeMillis = currentMillis;
        stepperThreeLaunched = true;
        stepper3.moveTo(-750);
    } else if (go == 9) {
      Serial.println("Closing time");
      //closingTime(); (Not implemented yet)
    if (((unsigned long)(currentMillis - hashtagOneMillis >= delayDown)) && stepperOneLaunched) {
      stepper1.moveTo(-stepper1.currentPosition());
    if (((unsigned long)(currentMillis - hashtagTwoMillis >= delayDown)) && stepperTwoLaunched) {
      stepper2.moveTo(-stepper2.currentPosition());
    if (((unsigned long)(currentMillis - hashtagThreeMillis >= delayDown)) && stepperThreeLaunched) {
      stepper3.moveTo(-stepper3.currentPosition());
    if (stepperOneLaunched == true) {
      stepper1.run();
      Serial.println("StepperOneLaunched");
    if (stepperTwoLaunched == true) {
      stepper2.run();
      Serial.println("StepperTwoLaunched");
    if (stepperThreeLaunched == true) {
      stepper3.run();
      Serial.println("StepperThreeLaunched");
    resetCount++;
  // Something went wrong and we are out of p.running loop. Reset counter and relaunch
  resetCount = 0;
  Serial.println("Re-start script");
// Call the Tweepy streaming Python script
void callTweepyStreaming() {
  p.begin("python");
  p.addParameter("/root/python/TwitterBlink/myStreamingTweepy.py");
  //p.addParameter("&2>1");
  p.runAsynchronously();
// Restarts program from beginning but does not reset peripherals and registers (Not using now)
void softwareReset() {
  asm volatile ("  jmp 0");
I am aware I am using MechanicalValue2 in two different places, it is for testing purposes.
Some of my ideas:
-Is it necessary to compare with (unsigned long) even with all variables participating in the comparison were previusly declared as unsigned long?
-Will microsteps use do any favor?
-Any extra thought?
Thanks in advance,
All your println's inside loop are slowing it done chronically - comment them out.
You need all the step() methods to be called frequently, think 10kHz or so.
This seems to be the same project as in your other Thread - why start a new Thread when all the useful info is already in the first Thread ?
…R
I thought it, Robin!
But also thought that now the topics are much further from each other. There I was talking about H-Bridge and heat problems, and now it is completely different.
Nevertheless, if I am wrong and both posts deserve the same place, I would be happy if moderators could move it!
Thanks!
