stepper not moving
i used one code the stepper moved
i used another peice of code with the same code the stepper dosent move
please help
code 1 ( the one that works )
int Pin1 = 3;
int Pin2 = 4;
int Pin3 = 5;
int Pin4 = 9;
int _step = 0;
boolean dir = true;// false=clockwise, true=counter clockwise
int count=0;
 pinMode(Pin1, OUTPUT);
 pinMode(Pin2, OUTPUT);
 pinMode(Pin3, OUTPUT);
 pinMode(Pin4, OUTPUT);
 switch(_step){
   case 0:
     digitalWrite(Pin1, LOW);
     digitalWrite(Pin2, LOW);
     digitalWrite(Pin3, LOW);
     digitalWrite(Pin4, HIGH);
   case 1:
     digitalWrite(Pin3, HIGH);
   case 2:
     digitalWrite(Pin4, LOW);
   case 3:
     digitalWrite(Pin2, HIGH);
   case 4:
   case 5:
     digitalWrite(Pin1, HIGH);
     case 6:
   case 7:
   default:
 if(dir){
   _step++;
 }else{
   _step--;
 if(_step>7){
   _step=0;
 if(_step<0){
   _step=7;
 delay(1);
code 2 ( the one that dosent work )
  const int AOUTpin=0;//the AOUT pin of the CO sensor goes into analog pin A0 of the arduino
const int DOUTpin=8;//the DOUT pin of the CO sensor goes into digital pin D7 of the arduino
const int ledPin=12;//the anode of the LED connects to digital pin D13 of the arduino
int limit;
int value;
const int LED = 13;
const int BUTTON = 7;
int val = 0;
int old_val = 0;
int state = 0;
int h;
int t;
 #include "DHT.h"
   DHT DHT_sens(8, DHT11);
int Pin1 = 3;
int Pin2 = 4;
int Pin3 = 5;
int Pin4 = 9;
int _step = 0;
boolean dir = true;
int count=0;
  Serial.begin(9600);//sets the baud rate
    pinMode(LED,OUTPUT);
pinMode(BUTTON, INPUT);
pinMode(DOUTpin, INPUT);//sets the pin as an input to the arduino
pinMode(ledPin, OUTPUT);//sets the pin as an output of the arduino
   DHT_sens.begin();
   Serial.begin (9600);
   Serial.println ("===============================================");
   Serial.println (" AUTO-SAFE ");
void loop(){
val = digitalRead(BUTTON);
if( val == HIGH && old_val == LOW) {
state = 1-state;
delay (10);
old_val = val;
if ( state == 1)
digitalWrite(LED,HIGH);
digitalWrite(LED, LOW);
 {if ( state == 1)
  Serial.print("ALARM AKNOWLEGED       ");
  Serial.print("ALARM UN ACKNOWLEGED       ");
value = analogRead(AOUTpin);//reads the analaog value from the CO sensor's AOUT pin
limit = digitalRead(DOUTpin);//reads the digital value from the CO sensor's DOUT pin
Serial.print("CO: ");
Serial.println(value);//prints the CO value
Serial.println("=============================");
if (value > 750) digitalWrite(ledPin, HIGH);
if (value < 750) digitalWrite(ledPin, LOW);
h = DHT_sens.readHumidity();
   t = DHT_sens.readTemperature();
   delay (1000);
   Serial.print ("Humidity:");
   Serial.print (h,0);
   // zero decimal
   Serial.print (" %\t");
   Serial.print ("Temparature: ");
   Serial.print (t,1);
   Serial.println (" *C");
   if (h > 50) digitalWrite(ledPin, HIGH);
Serial.print("ahhhhhh");
 switch(_step){
   case 0:
   case 1:
   case 2:
   case 3:
   case 4:
   case 5:
     case 6:
   case 7:
   default:
 if(dir){
   _step++;
 }else{
   _step--;
 if(_step>7){
   _step=0;
 if(_step<0){
   _step=7;
 delay(1);
please help
please im dying here
thanks you in adance :confused: :confused: :confused: :confused: :confused:
please ignore my scream in the code
sorry
Is your dying scream printed?
