I am trying to run stepper. It is not stepping in For loop. In step2, when I comment out "Mystepper.step(1); // Step the motor". Loop starts working and starts printing the steppings.
Please help me where am i doing mistake?
#include <Stepper.h>
const int StepsPerRev = 400; // Steps per revolution
Stepper Mystepper(StepsPerRev, 8, 9, 10, 11);
int AC, DI, ang, arm_sp;
int stepCount = 0;
const int Min_Angle = 1;
const int Max_Angle = 4;
const int Gear_Ratio = 50;
int Min_Arm_Sp = 100;
int Max_Arm_Sp = 1000;
volatile boolean Step_Direction = LOW; // Use volatile for variables modified by interrupts
const int ac = 5; // Pin for AC
const int di = 2; // Pin for DI
enum State {
IDLE,
Step1,
Step2,
Step4,
} state = IDLE;
pinMode(ac, INPUT);
pinMode(di, INPUT_PULLUP);
pinMode(A0, INPUT);
pinMode(A1, INPUT);
attachInterrupt(digitalPinToInterrupt(di), Direction, FALLING);
Serial.println("Setup complete. Waiting for input...");
handleReceivedData();
void handleReceivedData() {
Arm();
void dataReceive() {
AC = digitalRead(ac);
ang = analogRead(A1);
arm_sp = analogRead(A0);
DI = digitalRead(di);
void Direction() {
Step_Direction = !Step_Direction;
Serial.print("Direction changed to: ");
Serial.println(Step_Direction ? "Forward" : "Backward");
void Arm() {
dataReceive();
stepCount = 0;
int originalPosition;
ang = map(ang, 0, 1023, Min_Angle, Max_Angle);
arm_sp = map(arm_sp, 0, 1023, Max_Arm_Sp, Min_Arm_Sp);
ang = ang * Gear_Ratio;
// Print debug information
Serial.print("Mapped Angle: "); Serial.println(ang);
Serial.print("Mapped Speed: "); Serial.println(arm_sp);
// Ensure arm_sp is within valid range
if (arm_sp < Min_Arm_Sp || arm_sp > Max_Arm_Sp) {
Serial.println("Error: arm_sp out of range");
return;
switch (state) {
case IDLE:
if (AC == 1) {
Mystepper.setSpeed(0);
state = IDLE;
if (AC == 0) {
stepCount = 0;
state = Step1;
case Step1:
Serial.println("Step 1");
stepCount = 0;
originalPosition = stepCount;
Serial.print("Original Position: "); Serial.println(originalPosition);
state = Step2;
case Step2:
Serial.println("Step 2");
dataReceive();
// Debug output
Serial.print("AC: "); Serial.println(AC);
Serial.print("DI: "); Serial.println(DI);
Serial.print("Ang: "); Serial.println(ang);
Serial.print("Speed: "); Serial.println(arm_sp);
while (AC == 0) {
Serial.println("While loop Step 2");
dataReceive();
int targetPosition1 = originalPosition + ang;
Serial.print("Moving to Target Position1 in Step2: "); Serial.println(targetPosition1);
for (int i = 0; i < targetPosition1; i++) {
if (digitalRead(di) == LOW) {
Direction();
Serial.print("Step_Direction: "); Serial.println(Step_Direction);
Mystepper.setSpeed((Step_Direction ? 1 : -1) * arm_sp);
Serial.print("Stepping "); Serial.println(Step_Direction ? "Forward" : "Backward");
Serial.print("Stepping: "); Serial.println(i);
Serial.println("Cycle 1 Complete");
delay(200);
dataReceive();
arm_sp = map(arm_sp, 0, 1023, Min_Arm_Sp, Max_Arm_Sp);
Serial.print("Value of AC: "); Serial.println(AC);
Serial.print("Value of DI: "); Serial.println(DI);
if (AC == 1) {
Serial.print("Moving to Center Position in Step2: 0");
Mystepper.setSpeed(-arm_sp);
Mystepper.step(-1); // Step the motor in reverse
stepCount = 0;
state = IDLE;
Serial.println("Going to IDLE from Step2 - at 0 Position");
int targetPosition2 = originalPosition - ang;
Serial.print("Moving to Target Position2 in Step2: "); Serial.println(targetPosition2);
for (int x = targetPosition2; x < 0; x++) {
Direction();
Serial.print("Stepping: "); Serial.println(x);
Serial.println("Cycle 2 Complete");
dataReceive();
if (AC == 1) {
state = Step4;
Serial.println("Going to Step4 from Step2 - to reach 0 Position");
delay(200);
state = Step1;
case Step4:
int targetPosition3 = originalPosition;
Serial.print("Moving to Center Position in Step4: 0");
Mystepper.setSpeed(arm_sp);
Mystepper.step(-originalPosition); // Move to center position
state = IDLE;
Serial.println("Step 4 - Going to IDLE");
