Hello,
I am very new to coding and have thrown myself well into the deep end for a school project I need completed in a few weeks. The project is to design in CAD, 3D print and construct a scale rc tank that will eventually be line following.
I am struggling to get accelstepper and blynk to work together this is the hardware I am trying to use:
Arduino Uno
HC-06
4 x nema 23 steppers
4 x t6600 stepper drivers
I have spent the last three days trying to get everything to work together but it just isn't working and I can't find any examples that solve all of my problems without some issue. Here is some code I tried adapting could someone please tell me anything I forgot or need to change. Thank you so much in advance.
#define BLYNK_USE_DIRECT_CONNECT
// You could use a spare Hardware Serial on boards that have it (like Mega)
#include <SoftwareSerial.h>
SoftwareSerial DebugSerial(0, 1); // RX, TX
#define BLYNK_PRINT DebugSerial
#include <BlynkSimpleSerialBLE.h>
#include <AccelStepper.h>
#include <MultiStepper.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "LxY-KW2kIcoCYMXmEoTS2MjVTR5VhDWc";
// Select which 'port' M1, M2, M3 or M4.
//Adafruit_DCMotor *motor1 = AFMS.getMotor(1);
//Adafruit_DCMotor *motor2 = AFMS.getMotor(2);
//Adafruit_DCMotor *motor3 = AFMS.getMotor(3);
//Adafruit_DCMotor *motor4 = AFMS.getMotor(4);
AccelStepper stepper1(AccelStepper::DRIVER, 2, 3);
AccelStepper stepper2(AccelStepper::DRIVER, 4, 5);
AccelStepper stepper3(AccelStepper::DRIVER, 6, 7);
AccelStepper stepper4(AccelStepper::DRIVER, 8, 9);
//######### SETUP ######################################
// Debug console
DebugSerial.begin(9600);
DebugSerial.println("Waiting for connections...");
// Blynk will work through Serial
// 9600 is for HC-06. For HC-05 default speed is 38400
// Do not read or write this serial manually in your sketch
Blynk.begin(Serial, auth);
//########## LOOP ######################################
Blynk.run();
//######### Subrutines ################################
// This function will set the speed
BLYNK_WRITE(V0)
int pinValue = param.asInt(); // assigning incoming value from pin V1 to a variable
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("V0 Slider value is: ");
Serial.println(pinValue);
stepper1.setSpeed(pinValue);
stepper2.setSpeed(pinValue);
stepper3.setSpeed(pinValue);
stepper4.setSpeed(pinValue);
// Motor 1 Forward
BLYNK_WRITE(V1)
Serial.print("Motor 1 Forward: ");
if (pinValue == 1) {
stepper1.moveTo(1);
stepper3.moveTo(1);
if (pinValue == 0) {
stepper1.stop();
stepper3.stop();
// Motor 2 Forward
BLYNK_WRITE(V2)
Serial.print("Motor 2 Forward: ");
stepper2.moveTo(1);
stepper4.moveTo(1);
stepper2.stop();
stepper4.stop();
// Motor 1 Backward
BLYNK_WRITE(V3)
Serial.print("Motor 1 Backward: ");
stepper1.moveTo(-1);
stepper3.moveTo(-1);
stepper1.stop();
stepper3.stop();
// Motor 2 Backward
BLYNK_WRITE(V4)
Serial.print("Motor 2 Backward: ");
stepper2.moveTo(-1);
stepper4.moveTo(-1);
stepper2.stop();
stepper4.stop();
