stepper problems with DM860A driver
Hello I am trying to use a stepper motor with a DM860A microstep driver.
Driver Setting is for 400pulses/rev. In order to test my wiring and setup I am using an Arduino UNO running Tom Igoe's sketch "one revolution each direction". (reproduced below).
The only changes I have made are to set the pulses per rev to 400 and to initialize "stepper" to pins 8 and 9. Connections are 8 DIR 9 PUL and 13 ENBL. DIP switch setting 1 OFF, 2-8 ON
I also included a print statement to be sure that I was generating the correct number of pulses. The code runs and rotates the motor in both directions but not a full rev, only about a quarter of a rev.
Can anybody please suggest what I am doing wrong?
Thanks
Alan
Stepper Motor Control - one revolution
This program drives a unipolar or bipolar stepper motor.
The motor is attached to digital pins 8 - 11 of the Arduino.
The motor should revolve one revolution in one direction, then
one revolution in the other direction.
Created 11 Mar. 2007
Modified 30 Nov. 2009
by Tom Igoe
#include <Stepper.h>
int const stepsPerRevolution = 400; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9);
// set the speed at 60 rpm:
myStepper.setSpeed(60);
// initialize the serial port:
// step one revolution in one direction:
Serial.println("clockwise");
Serial.print (stepsPerRevolution);
myStepper.step(stepsPerRevolution);
delay(2000);
// step one revolution in the other direction:
Serial.println("counterclockwise");
myStepper.step(-stepsPerRevolution);
The standard Stepper library is not intended for stepper motor drivers that take step and direction signals. If you need a library then use the AccelStepper library
If you just want to do some tests try this Simple Stepper Code which does not need any library.
Depending on the specs for your driver you may or may not need to assert the enable pin.
...R
Stepper Motor Basics
Thanks Robin,
apologies for the dumb question and for this late response (been away for a few days). Its amazing how an apparently difficult problem melts away when you can get a helping hand
Alan
