stepper/servo combo problems
i have an easydriver+stepper connected to an arduino.
only step pin is attached to pin 48 (mega).
if i connect a servo to any PWM pin > stepper STEP pin starts getting pulses > stepper rotates constantly.
i trimmed down the code, to the bare minimum to reproduce.
mybe i need some filtering ?
#include <Servo.h>
Servo myservo;
  myservo.attach(9);
void loop() { }
power via modified ATX psu.
servo gets 5V and stepper 12V, arduino is powered via usb, ground is shared.
before i connected the servo i had no problems.
i also tried powering the servo via the easydriver regulated 5v output. same deal.
bump?
Misterious? Are you just using this code and the stepper is turning?
I had some trouble using servo.h and stepper.h at the same code.
Was not working together.
I made some test.
This code is working and no stepping of the motor - Servo is doing what is should too.
#include <Servo.h>
//int zaehler;
Servo servo1;
int dirpinh = 2;
int steppinh = 3;
int sleeph = 4;
int ms1h = 8;
int stepstateh = LOW;
int velh = 200;
int i;
long previousMicros;
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Stepper test!");
  servo1.attach(9);  // attaches the servo on pin 9 to the servo object
  pinMode(dirpinh, OUTPUT);
  pinMode(steppinh, OUTPUT);
  pinMode(sleeph, OUTPUT);
  pinMode(ms1h, OUTPUT);
  digitalWrite(sleeph, LOW);
void loop(){
  if (Serial.available() > 0) {
    int inByte = Serial.read();
  switch (inByte) {
    case 'a':
      Serial.println("Motor_left");
      digitalWrite(ms1h, LOW);
      digitalWrite(dirpinh, LOW);
      digitalWrite(sleeph, HIGH);
        i = 3200;
        while(i > 1)       // Iterate for 3200 flip / flops makes 1cycle with  my 1.8deg motor.
              if (micros() - previousMicros > velh)
                  previousMicros = micros();
                  if (stepstateh == LOW)
                      stepstateh = HIGH;
                      stepstateh = LOW;
                      digitalWrite(steppinh, stepstateh);
                    i--;
    case 'g':
     servo1.write(200);
     Serial.println("Servo_left");
    case 'h':
     Serial.println("Servo_middle");
     servo1.write(90);              // tell servo to go to position in variable 'pos'
    case 'j':
     servo1.write(0);
     Serial.println("Servo_right");
    default:
      Serial.println("micro");
      } //switch fuer eingegebene Daten
    } //serial serial available ende
  } //loop
When I was using delay for the stepping pin the servo was not working properly.
Here I mixed the ( Dan Thompson: EasyDriver 4.2 Tutorial ) tutorial of Dan Thomson with the blink without delay example and the servo.h example.
Hardware is Arduino 2009 - Stepper - Easydriver and some Servo.
Hope that helps!
[code][code][code][code][/code][/code][/code][/code]
