Stepper shaft spins but carriage not moving
Hello to all. I am new to arduino and to this forum and this will be my first post - I am hoping that someone may provide some advice or a solution.
I have combined 3 steppers from old cdrom drives into a mini 3D printer. All the electronics have been connected and I am able to activate each stepper motor. However, 2 of the 3 steppers move the shaft but the carriage is not moving - basically the carriage arm slips over the stepper shaft as it rotates. Any ideas how to get the carriage to move as the shaft spins?
Thanks.
taz1973:
You need to post a photo of the machine and maybe a diagram also.
At the moment I have not the slightest idea what sort of system you have.
...R
I agree that a picture may be a good start…sorry for that. Please find the pictures. Basically what happens is that the shaft of the stepper spins but the blue carriage is not moving - it just skips over the grooves of the stepper shaft. Any suggestions?
If the "blue carriage" has threads that match the grooves in the shaft, you need to add a tensioner of some sort.
Many linear positioners use a captive nut like this, which can't skip.
jremington:
The blue carriage may have had a button or pin that mated the thread on the lead screw, but is now missing. There seems to be a spring as part of the blue carriage that was a tensioner at one time.
Paul
Image from Reply #2 so we don’t have to download it. See this Image Guide
For the future please use a lower resolution image that will load more quickly. 640x480 is usually perfectly suitable
…R
