Grumpy_Mike:
So do I but unless you tell us exactly what you are doing then who knows what you are getting wrong.
So schematic, code and photograph all required.
You are right sorry.
Step C0 C1 C2 C3
1 1 0 1 0
2 0 0 1 0
3 0 1 1 0
4 0 1 0 0
5 0 1 0 1
6 0 0 0 1
7 1 0 0 1
8 1 0 0 0
int motorPin1 = 6;//Coil 1
int motorPin2 = 8; //Coil2
int motorPin3 = 7; //Coil3
int motorPin4 = 9; //Coil4
int delayTime = 500;
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
pinMode(motorPin3, OUTPUT);
pinMode(motorPin4, OUTPUT);
pinMode(13,OUTPUT);
int coil1s, coil2s, coil3s, coil4s;
if(Serial.available()==4){
coil1s=Serial.read()-48;
coil2s=Serial.read()-48;
coil3s=Serial.read()-48;
coil4s=Serial.read()-48;
Serial.print(coil1s,DEC);
Serial.print(coil2s,DEC);
Serial.print(coil3s,DEC);
Serial.println(coil4s,DEC);
setcoils(coil1s,coil2s,coil3s,coil4s);
/*setcoilds(1,0,0,0);
setcoilds(0,1,0,0);
setcoilds(0,0,1,0);
setcoilds(0,0,0,1); */
void setcoils(int coil1,int coil2,int coil3,int coil4){
digitalWrite(motorPin1, coil1);
digitalWrite(motorPin2, coil2);
digitalWrite(motorPin3, coil3);
digitalWrite(motorPin4, coil4);
digitalWrite(13,!digitalRead(13));
delay(delayTime);
The Arduino pins are connected to ULN2003 inputs. Motor pins are connected to the ULN2003 outputs.
I checked with multimeter the resistance between the wires and the red one of the motor gave different resistance so i supposed is the common.
I connected the motor common to the ULN2003 common and to external 7V (aprox) powersupply and join the grounds to Arduino.
Now it gets torque with some combinations but I cant find a combination to make it turn.
