Hi.
I´m a noob with code prog.
Can somebody help me coding a green led blinking slowly with the stepper runing forward at slow speed and a blue led blinking quickly with the stepper running backward at high speed?
I know it is super simple....but not for me.
Thanks in advance.
// constants won't change. They're used here to set pin numbers:
const int ForwardPin = 16; // the number of the pin that when high sends slide forward
const int StopForwardPin = 18; // the number of the pin that stops motor when forward
const int BackwardPin = 17; // the number of the pin that when high sends slide backward
const int StopBackwardPin = 19; // the number of the pin that stops the motor when backward
int smDirectionPin = 13; //Direction pin
int smStepPin = 27; //Stepper pin
// variables will change:
boolean ForwardState = 0; // variable for reading the micro-switch status
boolean StopForwardState = 0; // variable that stops motor when forward
boolean BackwardState = 0; // variable for reading the microswitch status
boolean StopBackwardState = 0; //variable that stops the motor when backward
int slidePosition = 2; // Tells progam what position the slide is in
setup inputs for switches and outs for motor pins
serial begin to read the switches to test for errors
// initialize the pin as an inputs:
pinMode(smDirectionPin, OUTPUT);
pinMode(smStepPin, OUTPUT);
// initialize the switch pins as inputs:
pinMode(ForwardPin, INPUT);
pinMode(StopForwardPin, INPUT);
pinMode(BackwardPin, INPUT);
pinMode(StopBackwardPin, INPUT);
this function turns motor foward
void SlideForward() {
// turn motor foward:
digitalWrite(smDirectionPin, HIGH); //Writes the direction to the EasyDriver DIR pin. (HIGH is clockwise).
/*turns the motor 1 step*/
for (int i = 0; i < 1; i++)
digitalWrite(smStepPin, HIGH);
delayMicroseconds(20);
digitalWrite(smStepPin, LOW);
delayMicroseconds(8050);
this function turns motor backwards
void SlideBackward() {
digitalWrite(smDirectionPin, LOW); //Writes the direction to the EasyDriver DIR pin. (LOW is counter clockwise).
/*Turns the motor fast 1 step*/
delayMicroseconds(400);
delayMicroseconds(1000);
Stop the motor form moving
void stopSlideFromMoving() {
// read the state of the switches value:
ForwardState = digitalRead(ForwardPin);
StopForwardState = digitalRead(StopForwardPin);
BackwardState = digitalRead(BackwardPin);
StopBackwardState = digitalRead(StopBackwardPin);
// check which pin 16 or 17 is HIGH:
if (ForwardState == HIGH && StopForwardState == HIGH && BackwardState == LOW) {
SlideForward();
} else if (ForwardState == HIGH && StopForwardState == LOW && BackwardState == LOW) {
stopSlideFromMoving();
if (BackwardState == HIGH && StopBackwardState == HIGH && ForwardState == LOW) {
SlideBackward();
} else if (BackwardState == HIGH && StopBackwardState == LOW && ForwardState == LOW) {
Make a test code just for blinking LEDs. Example code is found in IDE examples. When it works and You understand the code, incorporate it with the other code.
const int greenLedPin = 11; // Green LED for slow blinking
const int blueLedPin = 12; // Blue LED for quick blinking
// initialize the pins as an outputs:
pinMode(greenLedPin, OUTPUT);
pinMode(blueLedPin, OUTPUT);
//turns the motor 1 step
//for (int i = 0; i < 1; i++) //Commented out because have no effect on the behavior of this function
blinkSlowly();
//Turns the motor fast 1 step
blinkQuickly();
This function blings slowly the green LED
void blinkSlowly() {
static int forwardBlinkCounter = 0; // Counter for the number of delayMicroseconds
forwardBlinkCounter++; // Increment the counter every time the function is called
if (forwardBlinkCounter >= 250) {
static bool ledState = LOW; // Toggle state variable
ledState = !ledState; // Toggle the LED state
digitalWrite(greenLedPin, ledState); // Apply the new state to green LED
forwardBlinkCounter = 0; // Reset the counter
This function blings quickly the blue LED
void blinkQuickly() {
static int backwardBlinkCounter = 0; // Counter for the number of delayMicroseconds
backwardBlinkCounter++; // Increment the counter every time the function is called
if (backwardBlinkCounter >= 700) {
digitalWrite(blueLedPin, ledState); // Apply the new state to blue LED
backwardBlinkCounter = 0; // Reset the counter
SlideForward();
SlideBackward();
Of course, the advice in post #15 is excellent, and I strongly recommend following it. However, if you're not ready or prefer to continue playing with the current, somewhat restrictive beginner code, you might want to try a solution like this:
boolean movesNotAllowed = false; // Indicates if moves are restricted (true) or allowed (false)
blinkSlowly();
blinkQuickly();
if (StopForwardState == HIGH || StopBackwardState == HIGH) {
movesNotAllowed = true;
digitalWrite(greenLedPin, LOW); // Ensure the green LED is turned off if it is currently on
digitalWrite(blueLedPin, LOW); // Ensure the blue LED is turned off if it is currently on
if (movesNotAllowed == false) {
SlideForward();
SlideBackward();
Additional suggestion: Use bool instead of boolean, as recommended by the Arduino Reference page.
Thank you so much @bitslaver ....in fact it works but if i switch off the stepper rotation (cw or ccw) at the precise moment the respective led is on it remains always on ...even when i invert rotation direction....
I've made some changes, but I'm not certain they will work as expected
boolean blinkingOfLedsAllowed = true; // Indicates if blinki of LEDs are restricted (false) or allowed (true)
blinkSlowly();
blinkQuickly();
if (StopForwardState == HIGH || StopBackwardState == HIGH) { // If the stop states are in a default state
blinkingOfLedsAllowed = true; // The blinking of LEDs allowed
ensureLEDsAreOff();
if (blinkingOfLedsAllowed == true) {
* This function ensures LEDs are turned off wherever needed.
void ensureLEDsAreOff() {
blinkingOfLedsAllowed = false; // The blinking of LEDs is not allowed
if (ForwardState == HIGH && StopForwardState == HIGH && BackwardState == LOW) { // If forward input case is active
SlideForward();
} else if (ForwardState == LOW && StopForwardState == HIGH && BackwardState == LOW) { // If all three checking inputs are in default state
ensureLEDsAreOff();
} else if (ForwardState == HIGH && StopForwardState == LOW && BackwardState == LOW) { // If stop forward case is active
if (BackwardState == HIGH && StopBackwardState == HIGH && ForwardState == LOW) { // If backward input case is active
SlideBackward();
} else if (BackwardState == LOW && StopBackwardState == HIGH && ForwardState == LOW) { // If all three checking inputs are in default state
ensureLEDsAreOff();
} else if (BackwardState == HIGH && StopBackwardState == LOW && ForwardState == LOW) { // If we have stop backward case // If stop backward case is active
