Steppermotor help
Hey guys, i have a little problem i hope you can help me out :smiley:
I am useing a Sanguino board to start.
The PCB it is on has 5 buttons, one for +5 -5 +1 -1 steps on the motor and a go button. These are set to display on a LCD, however i cant seem to get anything to happen after i upload the program. Is there something i am doing wrong? Here is a copy of the program that was written for this task. I do understand i need to still tweak the variables for the motor however i believe i could get something to happen even if i dont have those veriables tweaked.
#include <LiquidCrystal.h>
// LiquidCrystal display with:
// rs on pin 1
// rw on pin 2
// enable on pin 3
// d0, d1, d2, d3 on pins 4, 5, 6, 7
LiquidCrystal lcd = LiquidCrystal(1, 2, 3, 4, 5, 6, 7);
int mot1 = 10;
int mot2 = 11;
int mot3 = 12;
int mot4 = 13;
int up = 14;
int down = 15;
int go = 16;
int down2 = 17;
int up2 = 18;
int goyes = 0;
int distance = 0;
//you need to change this to the value of how many cm/in you go per step
float distper_in = 0;
float distper_cm = 1;
//you need to change this to the value of how long it takes to go 1cm
float timeper_cm = 0;
int timet = 0;
//you might need to fiddle with this variable to get the stepper motor to work
//it is how many millisecconds it waits in between steps
int motime = 5;
  pinMode(mot1, OUTPUT);
  pinMode(mot2, OUTPUT);
  pinMode(mot3, OUTPUT);
  pinMode(mot4, OUTPUT);
  pinMode(up, INPUT);
  pinMode(down, INPUT);
  pinMode(go, INPUT);
  pinMode(up2, INPUT);
  pinMode(down2, INPUT);
void start(void)
  while (goyes == 0)
    if (digitalRead(up) == HIGH)
      distance++;
      lcd.clear();
      lcd.print("dist:");
      lcd.print(int(distance * distper_in));
      lcd.print(int(distance * distper_cm));
      lcd.print(int(distance * timeper_cm));
    if (digitalRead(down) == HIGH)
      distance--;
      lcd.clear();
      lcd.print("dist:");
    if (digitalRead(up2) == HIGH)
      distance += 5;
      lcd.clear();
      lcd.print("dist:");
    if (digitalRead(down2) == HIGH)
      distance -= 5;
      lcd.clear();
      lcd.print("dist:");
    if (digitalRead(go) == HIGH)
      goyes = 1;
  void runstuff(void)
    timet = millis();
    //step 1
    while(goyes == 1)
    if(distance != 0)
    digitalWrite(mot1, HIGH);
    digitalWrite(mot2, LOW);
    digitalWrite(mot3, HIGH);
    digitalWrite(mot4, LOW);
    distance--;
    delay(motime);
    //step2
        if(distance != 0)
    digitalWrite(mot1, LOW);
    digitalWrite(mot2, HIGH);
    distance--;
    delay(motime);
    //step3
        if(distance != 0)
    digitalWrite(mot3, LOW);
    digitalWrite(mot4, HIGH);
    distance--;
    delay(motime);
    //step4
        if(distance != 0)
    distance--;
    delay(motime);
    if (distance == 0)
      goyes = 2;
  if (goyes == 0)
  start();
    runstuff();
  while(goyes == 2)
  lcd.clear();
  lcd.print("time:");
  lcd.print(millis() - timet);
  lcd.print("dist:");
  delay(5000);
the LCD part is defined here
// rs on pin 1
// rw on pin 2
// enable on pin 3
// d0, d1, d2, d3 on pins 5, 4, 3, 2
void setup
void loop
Any help you can give me would be very much appreciated
Thanks :slight_smile:
If you’re using the LCD in four-bit mode, then you must connect D4, D5, D6 and D7 on the LCD to the Arduino’s pins.
alright to be honest i do not really know what you mean by that, i am useing a optrex japan PWB 24227-CEM LCD screen, i have traced the correct pins, and the ones from the code i posted above are going to the LCD. Also if the LCD screen works great. my biggest concern is the Motor, i can live without the screen.
You need to connect the LCD pins D4, D5, D6 and D7 to the Arduino, not the D0, D1, D2, D3 pins.
I don't understand this sentence. Is your LCD screen working properly or not?
oh ok, that makes sense now thanks. No what i mean is my primary concern is to get the steppermotor to work, if the LCD doesnt work it isnt the end of the world. I havent made the change you suggested yet though.
Hi, I have just foung the PWB 24227 display but I have no idea how to plug it in, do you have a datasheet?
Hi Kamis,
do you have a pin layout for the PWB 24227-CEM ?
