Hi!
I (also) have a question about the AccelStepper libry.
I read A LOT about this but can't find a solution for my problem.
I'm working on an Arduino Bartender. I move a platform over two axes with a steppermotor ( cnc/3d priny likly) and i would like to have moving the platform at startup to a button to set the home position.
I found some code from brainy-bits but can't make it work that good.
With the stepper libary in arduino it works perfect. (without the home position)
I found out that the steppen motor works best (without shaking at low speeds) at 1/32 steps. But I dont know how to set this up in this code.
My steppermotor does 200steps per revolution * 32steps/step = 3200.
In normal coditions i like to have a speed of 200rpm (work great with other code)
So 3200 * 200 = 640 000
So I filled this in by 'stepperX.setMaxSpeed' but the stepper turn very slowly.
I tried other numbers and setting my driver on 1/2 , 1/4, ... mode but nothing realy helps.
I think i miss something small but can't find it. Anyone who can?
my setup:
Nema 17 steppenmotor
STEPSTICK DRV8825 driver.
motor: 123-3d.nl Nema 17, 12V type: SL42S247A
driver: drv8825
code: brainy-bits.com
yt vid code : youtube
Sorry for my bad englisch, i'm Belgian. So if anyone can reply in Dutch, feel free!
#include "AccelStepper.h"
// Library created by Mike McCauley at http://www.airspayce.com/mikem/arduino/AccelStepper/
// AccelStepper Setup
AccelStepper stepperX(1, 9, 8); // 1 = Easy Driver interface
// NANO Pin 9 connected to STEP pin of Easy Driver
// NANO Pin 8 connected to DIR pin of Easy Driver
// Define the Pins used
#define home_switch 2 // Pin 2 connected to Home Switch (MicroSwitch)
// Stepper Travel Variables
long TravelX; // Used to store the X value entered in the Serial Monitor
int move_finished=1; // Used to check if move is completed
long initial_homing=-1; // Used to Home Stepper at startup
Serial.begin(9600); // Start the Serial monitor with speed of 9600 Bauds
pinMode(home_switch, INPUT_PULLUP);
delay(5); // Wait for EasyDriver wake up
// Set Max Speed and Acceleration of each Steppers at startup for homing
stepperX.setMaxSpeed(1000); // Set Max Speed of Stepper (Slower to get better accuracy)
stepperX.setAcceleration(1000); // Set Acceleration of Stepper
// Start Homing procedure of Stepper Motor at startup
Serial.print("Stepper is Homing . . . . . . . . . . . ");
while (digitalRead(home_switch)) { // Make the Stepper move CCW until the switch is activated
stepperX.moveTo(initial_homing); // Set the position to move to
initial_homing--; // Decrease by 1 for next move if needed
stepperX.run(); // Start moving the stepper
delay(5);
stepperX.setCurrentPosition(0); // Set the current position as zero for now
stepperX.setMaxSpeed(1000.0); // Set Max Speed of Stepper (Slower to get better accuracy)
stepperX.setAcceleration(1000.0); // Set Acceleration of Stepper
initial_homing=1;
while (!digitalRead(home_switch)) { // Make the Stepper move CW until the switch is deactivated
stepperX.run();
initial_homing++;
delay(5);
Serial.println("Homing Completed");
Serial.println("");
stepperX.setMaxSpeed(1000.0); // Set Max Speed of Stepper (Faster for regular movements)
// Print out Instructions on the Serial Monitor at Start
Serial.println("Enter Travel distance (Positive for CW / Negative for CCW and Zero for back to Home): ");
while (Serial.available()>0) { // Check if values are available in the Serial Buffer
move_finished=0; // Set variable for checking move of the Stepper
TravelX= Serial.parseInt(); // Put numeric value from buffer in TravelX variable
if (TravelX < 0 || TravelX > 1350) { // Make sure the position entered is not beyond the HOME or MAX position
Serial.println("");
Serial.println("Please enter a value greater than zero and smaller or equal to 1350.....");
Serial.println("");
Serial.print("Moving stepper into position: ");
Serial.println(TravelX);
stepperX.moveTo(TravelX); // Set new moveto position of Stepper
delay(1000); // Wait 1 seconds before moving the Stepper
if (TravelX >= 0 && TravelX <= 1350) {
// Check if the Stepper has reached desired position
if ((stepperX.distanceToGo() != 0)) {
stepperX.run(); // Move Stepper into position
// If move is completed display message on Serial Monitor
if ((move_finished == 0) && (stepperX.distanceToGo() == 0)) {
Serial.println("COMPLETED!");
Serial.println("");
move_finished=1; // Reset move variable
