Steppermotor with RAMPSV1.4
Hello,
Some students of mine would like to controle steppers with a RAMPS V1.4 that we had in our classroom. I placed a picture below.
But I have some questions about this:
  1. Is is possible to use the RAMPS V1.4 in combination with pushbuttons? If so, how?
  2. I found this code below on this forum, but I can't seem to get it running. Does anyone know what I'm doing wrong?
    (I change pins 8 and 9 to 54 and 55, because A0 = 54 and A1 = 55 on a MEGA)
Note: I used another code from this forum and then the stepper do work, so they are not broken.
// testing a stepper motor with a Pololu A4988 driver board or equivalent
// on an Uno the onboard led will flash with each step
// this version uses delay() to manage timing
byte directionPin = 54;
byte stepPin = 55;
int numberOfSteps = 100;
byte ledPin = 13;
int pulseWidthMicros = 20;  // microseconds
int millisbetweenSteps = 250; // milliseconds - or try 1000 for slower steps
  Serial.println("Starting StepperTest");
  digitalWrite(ledPin, LOW);
  delay(2000);
  pinMode(directionPin, OUTPUT);
  pinMode(stepPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  digitalWrite(directionPin, HIGH);
  for(int n = 0; n < numberOfSteps; n++) {
    digitalWrite(stepPin, HIGH);
    delayMicroseconds(pulseWidthMicros); // this line is probably unnecessary
    digitalWrite(stepPin, LOW);
    delay(millisbetweenSteps);
    digitalWrite(ledPin, !digitalRead(ledPin));
  delay(3000);
  digitalWrite(directionPin, LOW);
    // delayMicroseconds(pulseWidthMicros); // probably not needed
With regards,
Hans Vertongen
IMG_5779
Based on your other code that worked, I think you have enable and step switched over.
Edit: actually Direction and step.
What do you mean ?
I think that the step pin is 54.
Here is the Ramps to Mega pin mapping and analog pin to Arduino pin numbers.
#define PIN_A0   (54)
#define PIN_A1   (55)
#define PIN_A2   (56)
#define PIN_A3   (57)
#define PIN_A4   (58)
#define PIN_A5   (59)
#define PIN_A6   (60)
#define PIN_A7   (61)
#define PIN_A8   (62)
#define PIN_A9   (63)
#define PIN_A10  (64)
#define PIN_A11  (65)
#define PIN_A12  (66)
#define PIN_A13  (67)
#define PIN_A14  (68)
#define PIN_A15  (69)
Maybe this will help.
So I changed the code to the one below. But the motor stil doesn't run.
Anyone got other suggestions?
byte directionPin = 55;
byte stepPin = 54;
byte ledPin = 13;
  delay(2000);
  for (int n = 0; n < numberOfSteps; n++) {
  delay(3000);
It may be that you need to set the x enable pin high too.
Can you verify that the RAMPS code that you were using that worked earlier still does?
@wildbill got it right except the enable on those driver is active LOW.
Add this to your global variables:
const byte xEnable = 38;
Add this to setup():
  pinMode(xEnable, OUTPUT);
  digitalWrite(xEnable, LOW);
Code now works on my Mega/Ramps 1.4 board.
y enable = A2 (56)
z enable = A8 (62)
E0 enable = 24
E1 enable = 30
const byte directionPin = 55;
const byte stepPin = 54;
const byte ledPin = 13;
   delay(2000);
   delay(3000);
