Stepping driver servex fsd2b2p12
im fairly new to all this but looking for some guidance as i have done a fair bit of projects which were not to crazy.
But i have this cnc chuck that has a "kh56jm2-951" stepper and a servex fsd2b2p12 driver.
link to stepper
driver pdf attached.
now a few question as to how to determine the amperage to the driver as max output is 2 A.
could i run it off a 24v 4a power source?
As for wiring i have a few ideas but havent really tried any as i want to confirm my power supply first.
Any tips for wiring this up would help or links would be great.
Would it be easier to swap out this driver for one that is more commonly used for a beginner like my self?
FSD2B.pdf (155 KB)
That looks like a nice driver, only thing I see, appears it needs 2 separate inputs for CW/CCW, thats unusual and might be hard to find a ready made library for it. I suggest this board, I've used several successfully in different projects, it's easy to understand and will work with "step & direction" libraries, a good "beginner" driver, also check Pololu's website.
Your power supply should work fine (24V, at least 3 Amp).
Oh, and these link will be helpful:
http://forum.arduino.cc/index.php?topic=284828.0
http://forum.arduino.cc/index.php?topic=277692.0
hairtothepie:
Having more amps available is a good thing. The electrical device will only take what it needs. Just make sure the supply voltage is within the specified range - 10.8v to 33v for your driver.
This would be a cause of concern for me "Motor output current; About 2A max" (from the Power supply specifcations). Your stepper motor can take 2 amps and I would be happier with a driver that was not trying to work at its max limit.
outsider:
There is a switch to select between that and Step/Direction inputs
...R
Tnx @Robin2, didn't see it. :confused:
Thanks @outsider i have come across that board and a few others. Its great to have another persons perspective on that. I feel that i have many hours to go before i my self can figure this servex driver out for myself. So it may be best to grab some other drivers with librarys i can play with to get some more knowledge.
@robin2 thanks for all the post with the basics. Your time is greatly appreciated.
So im gonna be looking into a few different driver to figure out which one will work the best for what im try to get with this cnc chuck i have.
Thanks again for taking the time to reply.
hairtothepie:
The driver you have identified will work with the usual Arduino libraries.
...R
