Stereo BeatGen
Hi peoples - I ported code from one of the Loud Objects Noise Toy programs over to Arduino compatibility.
I altered a few values, so the sound/functionality is a bit different from the original - but it still pumps out some agressive stereo chiptunes. You can hear a sample of the original noise toy here - http://vimeo.com/944420
To use it -
connect audio left channel to pin 3 and right to pin 4
connect 2 momentary pushbuttons, one between pin 8 and ground, the other 9 and ground.
(pin 9 alters tempo, pin 8 beat sequence)
The original noise toy code can be found on the loud objects’ site, named “stereo.c” -
http://loudobjects.com/kit/
Oh and before i forget, here’s the code -
/*  Stereo BeatGen v1
 - adapted from code written by Loud Objects for the ATTiny85/NOISE TOY projects
 loudobjects.com
 - adapted/messed with for Arduino by Collin Cunningham
 me [at] collinmel.com
 assumes pins 3 & 4 connected to left & right audio
 momentary switches between 8 & 9 and GND
unsigned long NextRandom = 1;
unsigned long Bass_Start = 300, Bass_End = 600;
unsigned char Last_Val_Left = 1, Last_Val_Right = 1;
unsigned long Bass_Left_Period = Bass_Start, Bass_Right_Period = Bass_Start;
unsigned long Bass_Left_Sample = 1, Bass_Right_Sample = 1;
unsigned char Bass_Left_On = 1, Bass_Right_On = 1;
unsigned char Snare_Left_On = 1, Snare_Right_On = 1;
unsigned char Snare_Left_Sample = 1, Snare_Right_Sample = 1;
unsigned long Tempo_Period = 1200, Tempo_Outer = 1, Tempo_Sample = 1;
unsigned char Trax_Left[] = {
  1, 0, 2, 1, 1, 0, 3, 1};
unsigned char Trax_Right[] = {
  0, 1, 0, 1, 1, 2, 3, 1};
unsigned char Track_Index = -1;
unsigned long New_Rand = randomGen();
unsigned long NextRandom2 = 1;
unsigned long Snare_Length = 500;
  // SET PINS 3 AND 4 AS OUTPUTS
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  // SET PULL-UP RESISTORS ON PINS 9 AND 8
  pinMode(9, INPUT);
  pinMode(8, INPUT);
  digitalWrite(9, HIGH);
  digitalWrite(8, HIGH);
void loop(){
  NextRandom2 = NextRandom2 + 9;
  New_Rand = NextRandom2;
  // UPDATE SAMPLES
  if (Bass_Left_On)
    if (!(--Bass_Left_Sample))
      if ((Bass_Left_Period += 11) > Bass_End)
        Bass_Left_On = 0;
      Bass_Left_Sample = Bass_Left_Period;
      Last_Val_Left = 1 - Last_Val_Left;
  if (Bass_Right_On)
    if (!(--Bass_Right_Sample))
      if ((Bass_Right_Period += 13) > Bass_End)
        Bass_Right_On = 0;
      Bass_Right_Sample = Bass_Right_Period;
      Last_Val_Right = 1 - Last_Val_Right;
  if (Snare_Left_On)
    if (!(--Snare_Left_Sample))
      Snare_Left_Sample = New_Rand / 200;// % 10;
    if (!(--Snare_Length))
      Snare_Left_On = 0;
  if (Snare_Right_On)
    if (!(--Snare_Right_Sample))
      Snare_Right_Sample = New_Rand / 200;// % 10;
      Snare_Right_On = 0;
  // CHECK FOR NEXT BEAT
  if (!(--Tempo_Outer))
    Tempo_Outer = 10;
    if (!(--Tempo_Sample))
      if (++Track_Index == 8)
        Track_Index = 0;
      Tempo_Sample = Tempo_Period;
      Bass_Left_On = (Trax_Left[Track_Index] & 1);
      Bass_Right_On = (Trax_Right[Track_Index] & 1);
      Snare_Left_On = (Trax_Left[Track_Index] & 2);
      Snare_Right_On = (Trax_Right[Track_Index] & 2);
      Snare_Length = 5000;
      Bass_Left_Period = Bass_Start;
      Bass_Left_Sample = 1;
  // OUTPUT
  if (Last_Val_Left)
    PORTD |= (1 << 3);
    PORTD &= ~((1 << 3));
  if (Last_Val_Right)
    PORTD |= (1 << 4);
    PORTD &= ~((1 << 4));
  // BUTTON INPUT CHECKS
  //pin 8 for tempo
  if ((digitalRead(8)) == LOW)
    Tempo_Period = (random(10000,32767)/30 + 1000); // experiment with diff values for better range
  //pin 9 for beat
  if (digitalRead(9) == LOW)
    unsigned char i;
    for (i = 0; i < 8; i++)
      Trax_Left[i] = randomGen();
      Trax_Right[i] = randomGen();
unsigned long randomGen(void) //pseudo random from original sketch
  NextRandom = NextRandom * 3865 + 123;
  return ((NextRandom >> 16) & 32767);
experiment with values for additional funtimes
peaces -cc
Nice! Fun! Liked the case on the original. Now I know what to do with that HM55B compass! :D Thanks!
actually, do over - this one’s better:
 - originally written by Loud Objects for the ATTiny85/NOISE TOY projects
 loudobjects.com
  1, 2, 3, 0, 3, 2, 0, 1};
  2, 1, 0, 3, 1, 3, 0, 2};
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(2, INPUT);
  pinMode(9, INPUT);
  pinMode(8, INPUT);
  digitalWrite(5, LOW);
void loop(){
  // UPDATE SAMPLES
  if (Bass_Left_On)
        Bass_Left_On = 0;
  if (Bass_Right_On)
        Bass_Right_On = 0;
  if (Snare_Left_On)
      Snare_Left_On = 0;
  if (Snare_Right_On)
      Snare_Right_On = 0;
    Tempo_Outer = 10;
        Track_Index = 0;
  // OUTPUT
  if (Last_Val_Left)
    PORTD |= (1 << 3);
  if (Last_Val_Right)
    PORTD |= (1 << 4);
  //pin 8 for tempo
    randomSeed(analogRead(0));
    Tempo_Period = (random(1627) / 15 * 25); // experiment with diff values for better range
  //pin 9 for beat
    unsigned char i;
  NextRandom = NextRandom * 3865 + 131;
bzzzt*
cc
Wow, I’m going to have to digest that code for a while before I figure out what it does… but I think it would be a good upgrade for some of my projects.
Kudos and thanks!
