Still having trouble with digital reads
I posted this last week and changed my inputs to be INPUT_PULLUP and set the software to look for a LOW signal. Which works great when I just a little jumper from ground to pins 2-7 my corisponding outputs go low triggering pins 8-13 so when 2 is low pin 8 goes low and fires a relay, 3 goes low and fires 9 low and so on. My problem is when I actually attach my wire to my switch out in the field and trigger a contact closure on pin 2 all outputs go low? what am I missing. Do i need a resister some where. I am using this 4 channel relay board, 4 Channel 5V Relay Module - Wiki , it says it only need 15-20ma of current per relay so if all 4 are fired it is only drawing 80ma of power so i should be under what the limit of 200ma is. Here is my code, i am at a lost as to why a contact closure would cause this to happen but when I remove the wire and just jump to ground i dont have any issues? Sorry to be a pain but cannot wrap my head around what the difference is?
const int INPUTPINFIRST = 2;
const int INPUTPINLAST = 7;
const int OUTPUTPINFIRST = 8;
const int OUTPUTPINLAST = 13;
int pinWaitingFor = INPUTPINFIRST;
int soundTriggerCurrPin = OUTPUTPINFIRST;
  // Set up the pins for input.
  for ( int li_LoopPinIdx = INPUTPINFIRST ; li_LoopPinIdx <= INPUTPINLAST ; li_LoopPinIdx++ )
    pinMode ( li_LoopPinIdx , INPUT_PULLUP);
  // Set up the pings for output.
  for ( int li_LoopPinIdx = OUTPUTPINFIRST; li_LoopPinIdx <= OUTPUTPINLAST ; li_LoopPinIdx++ )
    pinMode ( li_LoopPinIdx , OUTPUT);
  // Set up the output pins as HIGH.
    digitalWrite ( li_LoopPinIdx , HIGH);
  // Read the input pin.
  int buttonState = digitalRead (pinWaitingFor );
  // Did they trigger it>'
  if ( buttonState == LOW )
    // Does this pin need a delay?
    if ( pinWaitingFor == INPUTPINFIRST )
      // Delay to let everyone in.
      delay ( 100 );
    // Fire the sound.
  PinTemporarilyLow ( soundTriggerCurrPin );
    // Set up for the next sound.
    soundTriggerCurrPin++;
    // Set up for next pin.
    pinWaitingFor++;
    // Are we out of pings?
    if ( pinWaitingFor > INPUTPINLAST )
      // Exit the loop.
      exit;
    } // End of if ( pinWaitingFor > INPUTPINLAST )
  } // End of if ( buttonState == HIGH )
} // End of loop ()
void PinTemporarilyLow ( int pinNumber )
  // Set the pin low.
  digitalWrite ( pinNumber , LOW );
  // Wait 1/10th of a second.;
Please edit your post and add code tags
Type
** **[code]** **
before your code
Type
** **[/code]** **
after your code
What is the distance from the switches to the Arduino?
Ok I edited it.
So in my head when i create a contact closure on pin 2 to ground it is pulling all pins to ground causing all output pins to go low also as far as I can create. I have 4 switches in the field about 40' away and if I only have one side hooked up to pin 2 and the other side of the switch to ground i can get pin 8 to fire low. As soon as i add the other switch to pin 3 is when all heck breaks loose and will fire remaining output pins. I can test it with my multi meter and it is open with no voltage and i get continuity when i turn the key. So what i can test works but i don't understand why when i hook up the physical switch it causes the issue.
