With Nicks Gammons RS485 Master code listed below (all be it played with by me)
can someone please tell me how i can get to serial.print the received slave message from the master.
Gammon Forum : Electronics : Microprocessors : RS485 communications Nick project is here.
it obviously receives something as the Led on pin d13 does not light up indicating that there is no error and that the message was acknowledged.
I would like the slave to pass messages back when polled and i believe this is already in place, i would like to be able to have several bytes sent in the return message which can be written to variable so that i can output them to the Host (pc connected to master module).
thanks
J.
#include "WConstants.h"
#include <NewSoftSerial.h>
#include "RS485_protocol.h"
NewSoftSerial rs485 (2, 3); // receive pin, transmit pin
const byte ENABLE_PIN = 4;
int channel = 0;
int data=0;
const byte LED_PIN = 13;
int incomingByte=0; // for incoming serial data
int thousands=0; int hundreds =0; int tens =0; int ones=0;
int inByte=0;
// callback routines
void fWrite (const byte what)
rs485.print (what);
int fAvailable ()
return rs485.available ();
int fRead ()
return rs485.read ();
rs485.begin (28800);
pinMode (ENABLE_PIN, OUTPUT); // driver output enable
pinMode (LED_PIN, OUTPUT); // built-in LED
} // end of setup
byte old_level = 0;
// read potentiometer
// byte level = analogRead (0) / 4;// commented out as it is now variable being written
byte level = (incomingByte);
// Serial.print(level);// print to serial monitor - for testing only
if (Serial.available() > 0) { //read value from host PC
hostprotocol();
// no change? forget it
if (level == old_level)
return;
// assemble message
byte msg [] = {
1, // device 1
2, // turn light on
level // to what level
// send to slave
digitalWrite (ENABLE_PIN, HIGH); // enable sending
sendMsg (fWrite, msg, sizeof msg);
delayMicroseconds (660);
digitalWrite (ENABLE_PIN, LOW); // disable sending
// receive response
byte buf [20];
byte received = recvMsg (fAvailable, fRead, buf, sizeof buf);
digitalWrite (LED_PIN, received == 0); // turn on LED if error
// only send once per successful change
if (received)
if (buf [0] != channel)
return; // not my device
if (buf [1] != 2)
return; // unknown command
byte msg [] = {
0, // device 0 (master)
data, // turn light on command received
//data
old_level = level;
} // end of loop
void hostprotocol() //Serial commands received from host
inByte = Serial.read();
switch (inByte)
case 79: //O out
DigitalOut();
void DigitalOut() {
// send data only when you receive data:
Serial.print("Digital OK");
// only if there are bytes in the serial buffer execute the following code
if(Serial.available()) {
//keep reading and printing from serial untill there are bytes in the serial buffer
//while (Serial.available()>0){
if (Serial.available()>2){ // got 3 characters
// assume comes in as hundreds, tens, ones
hundreds = Serial.read() - 0x30; // read the byte & convert from ASCII to a number
tens = Serial.read() - 0x30;
ones = Serial.read() - 0x30;
// now make into a digit
incomingByte = hundreds*100 + tens*10 + ones;
Serial.print(incomingByte);
//int value = (incomingByte);
