I recently bought a Sting Ray chassis from Parallax and am using an UNO R3, BOE Shield, and motor shield to control it. It’s my first experience outside of a BOE BOT, and I’m trying to learn as I go. I’m trying to make it autonomous for now, it has three PING sensors across the front, and I’m having some trouble getting them to work with each other. In this particular code, the Ping sensors will work, and I can read it through the serial monitor without the “forward”, “goRight”, “goleft” function calls in it. So, it will sit still and read distance from all three sensors, but if you add motor direction controls, the serial monitor stops working and the sensors don’t seem to all work. Am I out of memory? Or is my code terrible? I have tried other code including the “newPing” library and totally different code, but similar results.
#include <Ping.h>
// initialize
const int pingPin1 = 5 ; // pin used for the Ping Sensor
const int pingPin2 = 6; //Right Ping sensor
const int pingPin3 = 7; //Left Ping sensor
int BaudRate = 9600 ; // Baud rate
// set up
Serial.begin(BaudRate) ; // Setup Serial
//Setup Channel A
pinMode(12, OUTPUT); //Initiates Motor Channel A pin
pinMode(9, OUTPUT); //Initiates Brake Channel A pin
//Setup Channel B
pinMode(13, OUTPUT); //Initiates Motor Channel B pin
pinMode(8, OUTPUT); //Initiates Brake Channel B pin
digitalWrite(9, HIGH); //Engage the Brake for Channel A
digitalWrite(8, HIGH); //Engage the Brake for Channel B
delay(2000);
unsigned long duration1;
int inches1, inches2, inches3;
// Read distance 1
pinMode(pingPin1, OUTPUT);
digitalWrite(pingPin1, LOW);
delayMicroseconds(2);
digitalWrite(pingPin1, HIGH);
delayMicroseconds(5);
pinMode(pingPin1, INPUT);
duration1 = pulseIn(pingPin1, HIGH);
inches1 = microsecondsToInches(duration1);
unsigned long duration2;
// Read distance 2
pinMode(pingPin2, OUTPUT);
digitalWrite(pingPin2, LOW);
digitalWrite(pingPin2, HIGH);
pinMode(pingPin2, INPUT);
duration2 = pulseIn(pingPin2, HIGH);
inches2 = microsecondsToInches(duration2);
unsigned long duration3;
// Read distance 3
pinMode(pingPin3, OUTPUT);
digitalWrite(pingPin3, LOW);
digitalWrite(pingPin3, HIGH);
pinMode(pingPin3, INPUT);
duration3 = pulseIn(pingPin3, HIGH);
inches3 = microsecondsToInches(duration3);
if (inches2 > 20)
forward();
else if (inches1 <= 20)
goLeft();
else if (inches3 <= 20)
goRight();
Serial.print ("Distance : ") ;
Serial.print(inches1);
Serial.print("in, ");
Serial.print(inches2);
Serial.print(inches3);
delay (10);
void forward()
//Motor A forward @ full speed
digitalWrite(12, HIGH); //Establishes forward direction of Channel A
digitalWrite(9, LOW); //Disengage the Brake for Channel A
analogWrite(3, 250); //Spins the motor on Channel A at full speed
//Motor B backward @ half speed
digitalWrite(13, LOW); //Establishes backward direction of Channel B
digitalWrite(8, LOW); //Disengage the Brake for Channel B
analogWrite(11, 250); //Spins the motor on Channel B at full speed
void reverse(){
digitalWrite(9, HIGH); //engage the Brake for Channel A
digitalWrite(8, HIGH); //engage the Brake for Channel B
//Motor A reverse @ full speed
digitalWrite(12, LOW); //Establishes forward direction of Channel A
digitalWrite(13, HIGH); //Establishes backward direction of Channel B
void goRight(){
delay(20);
analogWrite(3, 200); //Spins the motor on Channel A at full speed
analogWrite(11, 200); //Spins the motor on Channel B at full speed
delay(200);
void goLeft(){
delay(20);
delay(200);
long microsecondsToInches(long microseconds)
return microseconds / 74 / 2;
