Stk500_disable(): protocol error
i get this error :
Arduino: 1.8.15 (Windows Store 1.8.49.0) (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
Sketch uses 8698 bytes (28%) of program storage space. Maximum is 30720 bytes.
Global variables use 310 bytes (15%) of dynamic memory, leaving 1738 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Commander\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Commander\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b57600 -D -Uflash:w:C:\Users\COMMAN~1\AppData\Local\Temp\arduino_build_628310/Thermistor-Serial.ino.hex:i
avrdude: Version 6.3-20190619
     Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "C:\Users\Commander\Documents\ArduinoData\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM7
     Using Programmer              : arduino
     Overriding Baud Rate          : 57600
     AVR Part                      : ATmega328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : Arduino
     Description     : Arduino
     Hardware Version: 2
     Firmware Version: 1.16
     Vtarget         : 0.0 V
     Varef           : 0.0 V
     Oscillator      : Off
     SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\COMMAN~1\AppData\Local\Temp\arduino_build_628310/Thermistor-Serial.ino.hex"
avrdude: writing flash (8698 bytes):
Writing | ################################################## | 100% 2.46s
avrdude: 8698 bytes of flash written
avrdude: verifying flash memory against C:\Users\COMMAN~1\AppData\Local\Temp\arduino_build_628310/Thermistor-Serial.ino.hex:
avrdude: load data flash data from input file C:\Users\COMMAN~1\AppData\Local\Temp\arduino_build_628310/Thermistor-Serial.ino.hex:
avrdude: input file C:\Users\COMMAN~1\AppData\Local\Temp\arduino_build_628310/Thermistor-Serial.ino.hex contains 8698 bytes
avrdude: reading on-chip flash data:
Reading | ##
avrdude: stk500_paged_load(): (a) protocol error, expect=0x10, resp=0x00
avrdude: stk500_cmd(): programmer is out of sync
avr_read(): error reading address 0x0000
read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0xe0
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
option enabled in File -> Preferences.
and this is "my" code (i say "my" because most of it is another persons code (which still dosent work but thats not why im here))
  Voltage divider
  R1 = 10K resistor (Vcc and common point)
  r2 = 10K THERMISTOR (GND and common point)
  Vo = pin A1 (common point
  Pin connections
  Arduino   device
  5V        resistor
  GND       Thermistor
  A0        Voltage divider Vo (common point between termistor and resistor)
  A1
  A2
  A3
  A4
  A5
  1
  2
  3
  4
  5
  6
  7
  8
  9
  10
  11
  12
  13
  SDA
  SLC
#define PW 13
int TR_PIN = A0;
double a1, b1, c1, d1, r2, r1, vo, tempC, tempF, tempK;
  a1 = 3.354016E-03 ;
  b1 = 2.569850E-04 ;
  c1 = 2.620131E-06 ;
  d1 = 6.383091E-08 ;
  r1 = 9720.0;
  pinMode(TR_PIN, INPUT);
  pinMode(PW, OUTPUT);
  digitalWrite(PW, HIGH);
  // read the temp
  vo = analogRead(TR_PIN);
  vo = vo / (1023.0 / 5.0);
  // voltage divider calculation
  // vo = 5 * r2 /(r1+r2)
  // solve for r2
  // get the exact value for voltage divider r1
  r2 = ( vo * r1) / (5.0 - vo);
  //equation from data sheet
  tempK = 1.0 / (a1 + (b1 * (log(r2 / 10000.0))) + (c1 * pow(log(r2 / 10000.0), 2.0)) + (d1 * pow(log(r2 / 10000.0), 3.0)));
  tempC  = (tempK - 273.15);
  tempF  = (tempC * 1.8) + 32.0;
  Serial.println("Temp - degK " + String(tempK));
  Serial.println("Temp - degC " + String(tempC));
  Serial.println("Temp - degF " + String(tempF));
  Serial.println(" ");
  if(tempF >= 150.0){
    digitalWrite(PW,LOW);
    Serial.println("its off at : ");
    Serial.println(tempF);
  Serial.println("its still on at : ");
idk why im getting this error and it happend out of no where
