Stk500 not in sync, old sketch stuck.
After reuploading my sketch to make some changes on my legit arduino uno board it failed to upload.
it takes about 3mins before the IDE simply pops up with ''some problems uploading''
I've tried the following:
-made sure the right coms+arduino type was selected.
-use resetbutton.
-use resetbutton just after clicking upload.
-powercycle arduino.
-restart IDE
-restart pc
-uninstalling uno's com driver.
-use a different computer.
-use a different sketch.
-use a empty sketch.
I've noticed the uno starts sending data over serial when the uploading is in progress
however it seems to be sending serial data the old sketch was supposed to send regardless of whats in the new sketch (empty or not)
This is the only output im getting:
De schets gebruikt 9056 bytes (28%)  programma-opslagruimte. Maximum is 32256 bytes.
Globale variabelen gebruiken 516 bytes (25%) van het dynamisch geheugen. Resteren 1532 bytes voor lokale variabelen. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM8 -b115200 -D -Uflash:w:C:\Users\q_fle\AppData\Local\Temp\arduino_build_475887/derp.ino.hex:i
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM8
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
How can i fix this? or did i somehow brick it?
