Hello!
I have a Arduino Uno Rev 3, and uses a macbook Pro running BigSur.
Here's the issue:
I upload a sketch (blink) and its works fine. I modify the sketch, reupload, still fine.
Then I disconnect the USB, and reconnects it.
Whatever sketch I try to upload, I get a "stk500_recv(): programmer is not responding".
I can disconnect/reconnect, reboot the mac, restart the IDE, press the reset button, nothing.
Then I reset the Arduino by connecting the reset and the GND, use dfu-programmer to erase, flash (with this one: ArduinoCore-avr/Arduino-usbserial-atmega16u2-Uno-Rev3.hex at master · arduino/ArduinoCore-avr · GitHub ) and reset. Unplug, replug. And tada, it works.
If I unplug and replug the USB after an upload, the whole cycle starts again.
Could some hero save me?
Thanks!
Let me add that I tried it again (the flashing part) and doesn't not connect anymore.
Also, I did a lot of research, and tried every single method proposed in this topic (avrdude: stk500_recv(): programmer is not responding - #193 by m1kta ).
Your post was MOVED to it's current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum .
Other general help and troubleshooting advice can be found here.
So, I performed the loopback test, and it is working.
Here's what I get when trying to upload in verbose mode:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/gaelrabier/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem1423201
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/var/folders/mt/b7p1_5sn18zd2rj33vz391vm0000gn/T/arduino_build_837584/Blink.ino.hex"
avrdude: writing flash (924 bytes):
Writing | avrdude: stk500_recv(): programmer is not responding
######avrdude: stk500_recv(): programmer is not responding
No one? Please, I am completely stuck here
Please bear in mind that USERS and MODERATORS are almost entirely volunteers and that we do NOT get paid to perform the extra duties.
We are simply enthusiasts like you.
We may have lives outside of Arduino, or be in a completely different time zone, or have family to care for.
Thank you for your cooperation.
Oh, did I offense you in any way? If so, sorry. It is just desperation talking, as I tried literally all solutions I found online, excepted buying a new board.
What is your operating system thinking about the board after disconnecting and reconnecting? Did the ports change?
If people don't know the answer, they will not reply. So there is a good chance that nobody had to deal with your problem themselves.
I'm also one that hasn't had the problem. And I live in a Linux/Windows world, not a Mac world.
Thanks Sterretje!
I am on Mac OS X Big Sur. I also use a UBC C to USB because there are only USB C on my machine.
May be I should try on a PC to rule out the the os problem
So, I saw an erratic behavior in the system report (kinda like the device manager in Windows world), where sometimes the Genuino would appear, sometimes not. Irrespective to that, the dfu-programmer always sees it, and the Arduino IDE + the Arduino web agent would see it also.
When the IDE sees it, the DFU-programmer also, but the mac doesn't list it in the USB's, I get the avr error. It happens systematically after a disconnect, and never comes back, unless I erase/flash/reset.
I ordered a new Arduino Uno rev3, a new USB cable from Arduino and a new USB C converter from Apple that has only one port. I will update here with the results. If the new converter + the new cable fail, while the new Arduino board works, I will attempt burning the old Arduino to see if it is a bootloader issue.
I solved it!
I was the USB-C hub. Apparently there's some magic happening in there that breaks the link/port/connection with the Arduino / Arduino IDE / avr.
I bought an official Apple USB to USB-C with only one port (Adaptateur USB-C vers USB - Apple (BE) ) and it works perfectly.
Thanks everyone for your help.
Kind regards,
system
Closed
September 28, 2021, 1:33pm
12
