Stk500_recv : programmer is not responding
Hello,i am trying to upload grblUpload from MIGRBL library to my arduino uno (clone) but when i upload it shows me this (avrdude: stk500_recv(): programmer is not responding) for 2-3 minutes it just shows me this again and again.I have already read many other threads but none helped me
usb cable is good
i tried another cable
i dont have an official arduino to burn bootloader or something, im not sure what this does
PC operating system, win 10
Arduino IDE ver 1.8.16
MY ARDUINO CLONE = Geekcreit UNO R3 ATmega328P
Shield i want to use = CNC Shield V3 3D
i tried to upload the code with nothing on tx and rx but it failed
arduino with other projects-codes upload and work fine
after 1-2 min its show me this ( the selected serial port avrdude: stk500_recv(): programmer is not responding
does not exist or your board is not connected )
error message↓
Arduino: 1.8.16 (Windows 10), Board: "Arduino Uno"
Sketch uses 29462 bytes (91%) of program storage space. Maximum is 32256 bytes.
Global variables use 1484 bytes (72%) of dynamic memory, leaving 564 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\CAPTAI~1\AppData\Local\Temp\arduino_build_637744/grblUpload.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\CAPTAI~1\AppData\Local\Temp\arduino_build_637744/grblUpload.ino.hex"
avrdude: writing flash (29462 bytes):
Writing | ################################################
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x10
option enabled in File -> Preferences.
Is the shield plugged in to your Uno clone board? If yes, does the error still occur if you unplug the shield and then try uploading again?
How big are other projects in compare with this one (Sketch uses 29462 bytes...)?
It looks like synchronization in transfer was lost. The byte was lost or so. If it happens at some sketch size then decreasing of transfer speed use to help. However, modified bootloader must be uplaoaded. :frowning:
In such case the problem is in the USB/serial transceiver or firmware vs OS, so another option could be use of external USB/serial transceiver connected to Rx,Tx,RESET.
yes i unplug it but shows me the same error
it's the first time i'm trying to upload such a big one sketch
other proj are small like 10 or 20% max and this one is 92%
also i saw other have the same problem with bootloader and firmware and that stuff
so thanks for answer, i think im just going to buy an official arduino
Arduino clones are good for small and simple projects
sry for my english btw :smile:
It is not necessary problem with the board. Many people use the clones but as I wrote, slower bitrate could solve the problem. Once you will have a new genuine Arduino, you can try to play with Arduino as ISP and the bootloading. :v:
