i want to test my arduino nano but i get this error
vrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
Probleem bij het uploaden naar het board. Zie http://www.arduino.cc/en/Guide/Troubleshooting#upload voor suggesties.
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Uncheck the checkbox next to "Show verbose output during: compilation"
Check the checkbox next to "Show verbose output during: upload
Click "OK"
Sketch > Upload
After the upload fails, you'll see a button on the right side of the orange bar "Copy error messages" (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
In a forum reply here, click on the reply field.
Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
Press "Ctrl + V". This will paste the upload output between the code tags.
Move the cursor outside of the code tags before you add any additional text to your reply.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\pascal\Desktop\arduino-nightly\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x74
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x74
avrdude done. Thank you.
Using Port : COM4
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x8d
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu. Note that the board you have selected is for the classic Arduino Nano. If you are using a Nano Every, Nano 33 IoT, Nano 33 BLE, or Nano 33 BLE Sense, then you need to select a different board. I can provide instructions for that if it's the case.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino board, you can find it like this:
Unplug your Arduino board from the computer.
Tools > Port
Note the ports, if any, listed in the menu.
Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
Plug your Arduino board into the computer.
Tools > Port - The new port listed in the menu is your Arduino board.
