stk500_getsync() attempt 1 of 10: not in sync: resp=0x08
If the board is getting hot and it has nothing connected, it is not good. Probably MCU draws high current and can be destroyed, or some other part like 16U2 or on-board regulator.
If it is classic UNO try to remove ATmega328P-PU from the socket and connect the board without it. If it gets hot, the board is affected otherwise the MCU.
