Computer: MacBook 13" running leopard 10.5.7
Arduino software: 0014, 0015, 0016
Arduino Board: Duemilanove
I've had my board for a couple of months. It worked when I first bought it, on the same software and system I'm using now. It's been in it's green plastic for a few months, and when I try to upload now, I get an error:
I've checked the serial port, board type, and I've tried resetting and starting with the board plugged in.
The transmitting and receiving lights do not flash. The power light is continuously on, and the pin 13 LED flashes once when I push reset.
I've taken the main chip out, and put it back in. There is a hint of corrosion on the chip holder contacts, but I'm not sure if it's enough to cause a problem. It looks like it' only on the top, and the pins should make contact further down.
I've looked over the board and there is no obvious physical defects.
Does anyone have any ideas?
(PS. I tried burning a new bootloader, but without the in-system programmer you are supposed to connect. I don't have one. Is it possible I've just stuffed up the existing bootloader?)
