stk500_recv() stk500_getsync() error arduino lilypad
quand j’essaye le téléversement de programe au arduino lilypad 328atmega
je reçois un message de stk500_rec
et j ai rein trouvée comme solution sur youtube ou forum
peut quel qu’un m’aider ??
voiçi toute qui est ecrit au arduino programe quand je televerse
Le croquis utilise 1046 octets (3%) de l’espace de stockage de programmes. Le maximum est de 30720 octets.
Les variables globales utilisent 9 octets (0%) de mémoire dynamique, ce qui laisse 2039 octets pour les variables locales. Le maximum est de 2048 octets.
C:\Users\younes\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/bin/avrdude -CC:\Users\younes\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\younes\AppData\Local\Temp\arduino_build_125019/gesture_control_robot_final.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is “C:\Users\younes\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf”
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x59
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x59
avrdude done. Thank you.
Problème de téléversement vers la carte. Voir http://www.arduino.cc/en/Guide/Troubleshooting#upload pour suggestions.
ERROR.txt (2.4 KB)
up
Please post in the French language board.
