Hi, I am playing with stm32 black pill (STM32F411CeU6) and I have tried out HardwareTimer example from stm32duino github: here
In example is shown how to use callback with parameter, but if I change MyData type from uint32_t to int or boolean it fails to compile.
This is an error message: no instance of overloaded function "HardwareTimer::attachInterrupt" matches the argument list -- argument types are: (std::_Bind<void (*(int *))(uint32_t *data)>) -- object type is: HardwareTimer
It is bug or is it just not implemented or something? Can I make it work?
Sorry, my mistake it is not due to type but because of volatile keyword which I add before. But I need this variable to be volatile. It is possible to make it work with volatile variable?
Here is the code :
#include <Arduino.h>
Timebase callback
This example shows how to configure HardwareTimer to execute a callback with some parameter at regular interval.
Callback toggles pin.
Once configured, there is only CPU load for callbacks executions.
#if !defined(STM32_CORE_VERSION) || (STM32_CORE_VERSION < 0x01090000)
#error "Due to API change, this sketch is compatible with STM32_CORE_VERSION >= 0x01090000"
#endif
#if defined(LED_BUILTIN)
#define pin LED_BUILTIN
#else
#define pin D2
#endif
volatile uint32_t MyData = 1; // Parameter used for callback is arbitrarily a pointer to uint32_t, it could be of other type.
// Every second, print on serial MyData. And increment it.
void Update_IT_callback(uint32_t* data)
Serial.println(*data);
*data = *data + 1;
#if defined(TIM1)
TIM_TypeDef *Instance = TIM1;
#else
TIM_TypeDef *Instance = TIM2;
#endif
// Instantiate HardwareTimer object. Thanks to 'new' instanciation, HardwareTimer is not destructed when setup() function is finished.
HardwareTimer *MyTim = new HardwareTimer(Instance);
// configure pin in output mode
pinMode(pin, OUTPUT);
MyTim->setOverflow(1, HERTZ_FORMAT); // 1 Hz
MyTim->attachInterrupt(std::bind(Update_IT_callback, &MyData)); // bind argument to callback: When Update_IT_callback is called MyData will be given as argument
MyTim->resume();
/* Nothing to do all is done by hardware. Even no interrupt required. */
Yes, it is compiling now. Thank you! But why should I use it there? I was never adding volatile keywords to any function parameter. I guess it is due to black magic of that bind function which I don't understand.
No, nothing to do with the bind function. If you're going to pass your Update_IT_callback() function a pointer to a volatile uint32_t, then that's what you have to put in the function definition and prototype.
