STM32F4x dual SPI for SD card and display
I'm hoping to use two SPI channels so that I can load images from SD card and push bits to the display concurrently. This seems a good approach to me as little time will be wasted.
I also considered using jpg compression but I suspect the time taken to decode will be longer than time saved.
Does this seem like a good scheme or are the time savings not worthwhile?
Most examples I can find are for ESP32 but I think alterations for STM32 should be do able - not sure about spiffs.
Any advice most welcome.
Best Regards
picclock
The most basic STM32F4 can certainly support two SPI buses, and there's a good chance it has native SDIO peripheral for your SD card.
Which STM32F4 dev board do you have? Nucleo? Discovery kits? Black pill?
Black Pill. Hoping to use TFT_eSPI library for display and SDFat32 for sdcard if I can persuade it to work with SPI2.
Using STM32F401 atm, so no sdio, also spi card interface on rear of display which makes it convenient :slight_smile:.
Best Regards
picclock
Only if your libraries allow for buffered I/O that transfers the buffers while your code is doing other things.
