"Firstly, I chose an LED blink code and selected the board NUCLEO_8S208RB. When I verified the code, an error occurred.
I also installed the Cosmic compiler with the license key. I uploaded the license file and clicked 'Done'.
However, after clicking 'Done', the same window popped up again."
Yes, and now you want what?
Because you're using IDE 2.x, your topic was moved to the dedicated IDE 2.x section of the forum.
I can't help you with your problem.
xfpd
July 9, 2024, 7:04pm
4
The pop-up says your license file must be stored.
"Thanks for all, but I resolved my problem with my senior."
Do you mind sharing the solution so others can benefit from it,
"I was filling out the license for the Cosmic compiler that I was using on my system. The Arduino and the Cosmic compiler were separate products. I applied and filled out a separate license for the Arduino-related Cosmic compiler product, which solved the problem."
system
Closed
January 11, 2025, 8:48am
8
