stock on conn.connect
//#include <DHT.h>
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#define sensorPin1 0
//#define sensorPin2 D2
//#define typeDHT DHT11
//DHT dht(sensorPin1, typeDHT);
char ssid[] = "AndroidAP";                 // Network Name
char pass[] = "123456789";                 // Network Password
byte mac[6];
WiFiServer server(80);
IPAddress ip(192, 168, 43, 72);
IPAddress gateway(192, 168, 48, 1);
IPAddress subnet(255, 255, 255, 0);
WiFiClient client;
MySQL_Connection conn((Client *)&client);
char INSERT_SQL[] = "INSERT INTO test.reza(a) VALUES(1)";
//char INSERT_SQL[] = "INSERT INTO officeto_plants.TBL_READINGS(ID_PLANT, AIR_HUMIDITY, AIR_TEMPERATURE, SOIL_MOISTURE_1, SOIL_MOISTURE_2) VALUES (1, NULL, NULL, %d, %d)";
char query[128];
IPAddress server_addr(192, 168 , 43, 59);         // MySQL server IP
char user[] = "reza";           // MySQL user
char password[] = "reza1501";       // MySQL password
  pinMode(sensorPin1, INPUT);
  //pinMode(sensorPin2, INPUT);
  Serial.println("Initialising connection");
  Serial.print(F("Setting static ip to : "));
  Serial.println(ip);
  Serial.println("");
  Serial.println("");
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.config(ip, gateway, subnet);
  WiFi.begin(ssid, pass);
    delay(200);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi Connected");
  WiFi.macAddress(mac);
  Serial.print("MAC: ");
  Serial.print(mac[5], HEX);
  Serial.print(":");
  Serial.print(mac[4], HEX);
  Serial.print(":");
  Serial.print(mac[3], HEX);
  Serial.print(":");
  Serial.print(mac[2], HEX);
  Serial.print(":");
  Serial.print(mac[1], HEX);
  Serial.print(":");
  Serial.println(mac[0], HEX);
  Serial.println("");
  Serial.print("Assigned IP: ");
  Serial.print(WiFi.localIP());
  Serial.println("");
  Serial.println("Connecting to database");
  while (conn.connect(server_addr, 3307, user, password) != true) {
    delay(200);
    Serial.print ( "." );
  Serial.println("");
  Serial.println("Connected to SQL Server!");
  int soil_hum = 1024 - analogRead(sensorPin1);
  //float t = dht.readTemperature();
  //Serial.println(t);
  delay(5000); //10 sec
  sprintf(query, INSERT_SQL);
  //sprintf(query, INSERT_SQL, soil_hum, t);
  Serial.println("Recording data.");
  Serial.println(query);
  MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
  cur_mem->execute(INSERT_SQL);
  delete cur_mem;
this code stock on conn.connect()
pls help
Please read the sticky post "How to use this forum - please read" at the top of the board.
