I have function that i want to run every 15 minutes.
I am entering numbers from the keyboard. While entering the numbers and if 15 minutes have passed
I want my sketch to stop what it is doing and start the function that it supposed to run after 15 minutes.
Save the value of millis() when input starts in an unsigned long variable then, each time through loop() check whether 15 minutes have passed run the second function
if (millis() - startTime >= 1000UL * 60 * 15)
//code or function to run after 15 minutes
If you are receiving serial data you may also be interested in the examples Serial Input Basics which should probably be very suitable for your described requirement.
