//MQTT PIR On Off
const char *topicPIRonoff = "protect/PIRonoff"; // Enable/disable PIR
const char *topicPIRonoffStatus = "protect/PIRonoffStatus"; // Send PIR status
//PIR On Off only proceed if incoming message's topic matches
if (String(topic) == topicPIRonoff) {
PIRonoffStatus = !PIRonoffStatus;
SerialMon.print("PIRonoffStatus:");
SerialMon.println(PIRonoffStatus);
mqtt.publish(topicPIRonoffStatus, PIRonoffStatus ? "ON" : "OFF");
If I send the topic ON it will turn the PIR on and off will turn the PIR off. I have a web UI front end that gets off sync so I want to revise code to not toggle.
If I send a topic of ON then PIRonoff = ON and PIRonoffStatus = ON
If I send a topic of OFF then PIRonoff = OFF and PIRonoffStatus = OFF
At moment UI can be ON and the device MQTT is off.
Revised code to
// PIR On/Off only proceed if incoming message's topic matches
if (String((char*)payload) == "ON") {
PIRonoffStatus = true;
} else if (String((char*)payload) == "OFF") {
PIRonoffStatus = false;
SerialMon.println("Invalid payload value for PIR on/off");
return;
The error message "Invalid payload value for PIR on/off" is being printed because the payload variable is not equal to "ON" or "OFF". This could be because there are some leading or trailing spaces in the payload, or the case of the letters is different.
To fix this, you can use the trim() function to remove any leading or trailing spaces from the payload, and the toLowerCase() function to convert the payload to lowercase. Here's an updated code that does this:
vbnetCopy code
String payloadStr = String((char*)payload).trim().toLowerCase();
if (payloadStr == "on") {
} else if (payloadStr == "off") {
return;
This code trims the payload using the trim() function and converts it to lowercase using the toLowerCase() function. The rest of the code is the same as before.
I hope this helps! Let me know if you have any other questions.
Z
revise the code presents errors with invalid use of 'void' but the line looks ok
added debug to print revived has some extras in it?
18:29:21.535 -> Message arrived [protect/PIRonoff]: OFF
18:29:21.535 -> Received payload: OFFsONFyVolts
18:29:21.535 -> Invalid payload value for PIR on/off
20:14:58.093 -> Message arrived [batchprotect/PIRonoff]: ON
20:14:58.093 -> PIRonoffStatus:1
20:14:58.093 -> Received payload: ONleepTSIM
20:15:01.511 -> Message arrived [batchprotect/PIRonoff]: OFF
20:15:01.559 -> PIRonoffStatus:0
20:15:01.559 -> Received payload: OFFStatusONtusConnected
Second doesnt work
String payloadStr = String((char*)payload);
payloadStr.trim(); // trim whitespace from payload string
//payloadStr.toLowerCase(); // trim whitespace from payload string
//payloadStr = payloadStr.substring(0, 3); // Limit to first 2 characters
if (payloadStr == "ON") {
} else if (payloadStr == "OFF") {
SerialMon.print("Received payload: ");
SerialMon.println(payloadStr);
return;
Output of non working code
20:23:26.905 -> Message arrived [batchprotect/PIRonoff]: ON
20:23:26.905 -> Invalid payload value for PIR on/off
20:23:26.905 -> Received payload: ONleepTSIM
20:23:30.327 -> Message arrived [batchprotect/PIRonoff]: OFF
20:23:30.327 -> Invalid payload value for PIR on/off
20:23:30.327 -> Received payload: OFFeepTSIM
13:04:07.369 -> Message arrived [protect/PIRonoff]: ON
13:04:07.369 -> ONsupplyVolts
13:04:07.416 -> Invalid payload value for PIR on/off
13:04:07.416 -> Received payload: ONsupplyVolts
