Stop Counting Motor Steps In Void Loop
In my code below, I have it that when I press the button, (state == 1), within that if function the motor runs. And when it is off, the motor does not run.
The issue I am running into is even after the motor is off, it continues to count steps in the void loop. So after a period of time when pushing the button again, it will either go forward or backward depending on where it is in the loop.
What I need my code to do is stop counting steps once I turn the motor off so it picks back up where it left off in the void loop when the button is pressed again.
Thank you.
void loop(){
  /*Here we are calling the rotate function to turn the stepper motor*/
  /*One revolution of this motor is 1600 microsteps*/
  /*driver is 8 microstep/step operation*/
  /*Motor runs at 200 steps for every 360 degree rotation*/
  rotate(-1000, 0.15); //The motor rotates 1000 microsteps (5/8 of a revolution) clockwise with a speed of 0.15
  delay(750);
  rotate(1000, 0.15); //The motor rotates 1000 microsteps (5/8 of a revolution) counter clockwise with a speed of 0.15
  delay(750);
void rotate(int steps, float speed){
  val = digitalRead(buttonPin);
    // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (val == HIGH && old_val == LOW) {
    state = 1-state;
  old_val=val;
  if (state == 1) {
  /*This section looks at the 'steps' argument and stores 'HIGH' in the 'direction' variable if */
  /*'steps' contains a positive number and 'LOW' if it contains a negative.*/
  int direction;
  if (steps > 0){
    direction = HIGH;
  }else{
    direction = LOW;
  speed = 1/speed * 70; //Calculating speed
  steps = abs(steps); //Stores the absolute value of the content in 'steps' back into the 'steps' variable
  digitalWrite(smDirectionPin, direction); //Writes the direction (from our if statement above), to the EasyDriver DIR pin
  /*Steppin'*/
  for (int i = 0; i < steps; i++){
    digitalWrite(smStepPin, HIGH);
    delayMicroseconds(speed);
    digitalWrite(smStepPin, LOW);
  digitalWrite(smEnablePin, LOW); //Enabling the motor, so it will move when asked to
  cycle = count++;
      // picture loop
  u8g.firstPage();
  do {
    u8g.setFont(u8g_font_profont12);
    u8g.drawStr( 0, 10, "Cycle");
    u8g.drawStr( 0, 20, "Count:");
    u8g.setPrintPos(40, 20);
    u8g.print(cycle);
    u8g.drawStr( 0, 35, "Lux:");
    u8g.setPrintPos(25, 35);
    u8g.print(event.light);
  } while ( u8g.nextPage() );
  } else{
  digitalWrite(smEnablePin, HIGH); //Disabling the motor, so it will move when asked to
      // picture loop
  u8g.firstPage();
  do {
    u8g.print(cycle);
  } while( u8g.nextPage() );
Set a flag when you stop the motor. Make counting dependant on the state of the flag.
Would I put the flag within the void loop or void rotate?
Yeowch! You have used a function but that function does everything! It reads inputs, makes decisions, drives outputs and writes stuff on the screen.
Functions should have simple names with 1, 2 or 3 words in the name. The name should describe what the function does. It should not do anything else. If it does something else (like writing to the screen) that's called a "side effect" and it's as bad as a medical side effect.
Start by reading Planning and Implementing an Arduino Program
Then look at your program again. Can you name each of the operations that occurs? Make a function for those: readInputs() decideWhenToRun() rotateMotor() displayScreen() and so on.
