Stop dc engine from loop and print Finish "once"
Hy guys.
Finally i reached to stop the DC engine from with a while statement.
Now i want to Print something that tells me that the look has gone through but i dont know where tu put it.
Now its inside the loop so it writes not only once. Putting after the loop bracket i get an error :-/
Any hint please?
int motorPin1=2;
int motorPin2=3;
int x = 2;
void setup(){
  pinMode(motorPin1,OUTPUT);
  pinMode(motorPin2,OUTPUT);
void motorStop(){
  digitalWrite(motorPin1,LOW);
  digitalWrite(motorPin2,LOW);
void loop(){
    while(x <= 3){
    motorStop();                    // Motor Stop
    digitalWrite(motorPin1,HIGH);   // Motor Vor
    digitalWrite(motorPin1,LOW);   // Motor Vor
    digitalWrite(motorPin2,HIGH);
    Serial.print(x);
    x++;
  motorStop();
  Serial.print("Finish Loop");
Just take the parts of loop() that you don't want to repeat forever, and put them in the end of setup().
int motorPin1 = 2;
int motorPin2 = 3;
int x = 2;
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  while (x <= 3)
    digitalWrite(motorPin1, HIGH);  // Motor Vor
    digitalWrite(motorPin2, LOW);
    digitalWrite(motorPin1, LOW);  // Motor Vor
    digitalWrite(motorPin2, HIGH);
    Serial.print(x);
    x++;
  motorStop();
void motorStop()
void loop() { }
I don't understand your description what kind of functionality you want to have.
What your code is doing is
stop motor
run motor clockwise for one second
stop motor
run motor counterclockwise for one second
loop does what its name says loop = looping = repeating infinetely
repeat all code
only as x contains value 4 the condition is false
if this has repeated two time because x is initialised with value 2
repeat
while(x <= 3){
(4 <= 3) evaluates to false
=> code inside the while-loop is not executed
the code below the while-loop will be executed
This means make the execution of the serial-message conditional
As a recommendation for future postings describe the wanted functionality in this way
no programming-terms
just everyday-words
but describe each single step of what shall happen
best regards Stefan
Thanks :slight_smile:
1
2
3
Finish Loop with: 3 loops.
It's fully documented in the Bare Example sketch that ships with the IDE:
