hi
what i want is.. ir sending one time to set the air conditoner to 23 C when temperature in range.. what happen know .. my coding are keep looping.. and keep sending ir to my air conditoner..
here is my code
if there are led myb ican use "else ... digitalwrite... low..
but know im using ir led..
and by the way im using arduino mega
#include "DHT.h"
#include <LiquidCrystal.h>
#include <IRremote.h>
#define DHTPIN 7 //Define sensor pin(pin 12)
#define DHTTYPE DHT22 //What sensor use
DHT dht(DHTPIN, DHTTYPE);//Create sensor object
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
float h=0,t=0,e=0;
const int ledPin = 13; //LED pins for temperature control
long previousMillis = 0;
long interval = 1000; //Read sensor each 2 seconds
IRsend irsend;
unsigned int raw1[210]={ 12292, 1176, 640, 1604, 668, 1572, 668, 440, 640, 464, 640, 444, 692, 364, 920, 972, 164, 260, 668, 1576, 664, 440, 668, 348, 1840, 404, 728, 376, 1624, 256, 1088, 444, 640, 1600, 640, 468, 668, 436, 784, 248, 716, 412, 720, 320, 1700, 436, 896, 1572, 640, 1604, 640, 464, 668, 368, 712, 380, 724, 392, 716, 376, 732, 344, 764, 288, 816, 376, 732, 420, 688, 460, 672, 440, 780, 284, 684, 444, 664, 1096, 21148, 400, 680, 452, 652, 416, 692, 492, 616, 400, 704, 440, 668, 420, 688, 464, 644, 464, 640, 468, 640, 468, 636, 472, 636, 468, 724, 384, 640, 468, 636, 468, 640, 464, 644, 416, 692, 468, 636, 420, 688, 412, 696, 408, 700, 400, 864, 980, 14436, 244, 1848, 592, 640, 468, 636, 472, 636, 436, 672, 468, 636, 472, 636, 496, 612, 468, 640, 464, 640, 1204, 200, 212, 628, 468, 636, 1604, 640, 1600, 640, 1600, 640, };
unsigned int raw28[211]={ 9184, 4336, 664, 1584, 664, 1584, 664, 448, 664, 444, 696, 416, 640, 472, 668, 1580, 668, 1584, 664, 1584, 664, 1584, 664, 1588, 664, 444, 664, 448, 640, 1608, 668, 444, 692, 1556, 664, 448, 668, 444, 664, 448, 692, 416, 696, 416, 692, 1556, 668, 1584, 664, 1584, 664, 444, 668, 444, 668, 444, 664, 448, 664, 444, 668, 444, 668, 444, 668, 444, 692, 416, 668, 444, 668, 444, 664, 448, 664, 448, 664, 1584, 664, 448, 664, 444, 668, 444, 696, 416, 664, 448, 664, 444, 668, 444, 696, 416, 692, 1556, 668, 444, 664, 448, 664, 444, 668, 444, 668, 444, 696, 416, 724, 1528, 664, 444, 664, 448, 664, 444, 668, 444, 696, 416, 692, 420, 664, 448, 664, 444, 668, 444, 668, 444, 664, 448, 664, 444, 640, 472, 668, 444, 664, 448, 664, 448, 664, 444, 668, 444, 692, 420, 692, 420, 664, 444, 696, 416, 640, 472, 692, 1556, 668, 444, 664, 448, 664, 444, 668, 444, 668, 444, 668, 444, 664, 448, 664, 448, 636, 472, 696, 416, 664, 1584, 668, 444, 668, 1584, 664, 444, 692, 420, 692, 420, 664, 444, 668, 444, 696, 1556, 692, 1556, 664, 1584, 664, 1584, 668, 444, 696, 1556, 692, 1556, 664, 1584, 668,};
unsigned int raw27[212]={ 9132, 1348, 400, 208, 264, 2168, 664, 1584, 664, 1584, 668, 444, 664, 444, 668, 444, 664, 448, 692, 1560, 664, 1584, 664, 1584, 664, 1584, 668, 1584, 664, 1584, 664, 1584, 664, 448, 664, 444, 668, 1584, 664, 448, 664, 444, 668, 444, 668, 444, 664, 448, 664, 1584, 668, 1580, 668, 1580, 668, 444, 668, 444, 668, 444, 664, 444, 668, 448, 664, 444, 664, 448, 668, 444, 664, 444, 668, 444, 668, 444, 668, 444, 664, 448, 664, 1584, 668, 444, 664, 444, 696, 416, 668, 444, 696, 416, 668, 440, 668, 444, 668, 444, 692, 1556, 668, 444, 668, 444, 668, 444, 668, 444, 664, 444, 668, 444, 696, 1552, 668, 444, 668, 444, 668, 440, 672, 440, 672, 440, 668, 444, 696, 416, 668, 440, 672, 440, 672, 440, 672, 440, 668, 444, 668, 444, 668, 440, 696, 416, 668, 444, 668, 444, 668, 440, 696, 416, 672, 440, 668, 444, 668, 440, 672, 440, 696, 1180, 4352, 304, 832, 444, 668, 440, 672, 444, 668, 440, 696, 416, 668, 440, 672, 1176, 1268, 244, 672, 1580, 668, 444, 668, 440, 672, 440, 696, 416, 668, 444, 668, 1580, 672, 1580, 668, 1580, 668, 440, 672, 440, 696, 1556, 668, 1580, 668, 1580, 668, };
unsigned int raw26[213]={ 9160, 4356, 668, 1584, 664, 1584, 664, 444, 668, 444, 664, 448, 664, 448, 664, 1584, 664, 1584, 664, 1584, 664, 1584, 668, 1584, 664, 444, 664, 1588, 688, 420, 664, 448, 636, 1612, 692, 420, 664, 444, 668, 444, 664, 448, 692, 420, 692, 1556, 664, 1584, 664, 1584, 664, 448, 664, 448, 660, 448, 692, 420, 640, 472, 664, 448, 688, 420, 668, 444, 664, 448, 636, 472, 640, 472, 664, 448, 640, 468, 692, 1560, 664, 444, 640, 472, 640, 472, 664, 444, 640, 472, 664, 448, 664, 448, 664, 444, 668, 444, 640, 472, 668, 444, 640, 468, 668, 444, 668, 444, 664, 448, 664, 1584, 664, 444, 668, 444, 640, 472, 640, 472, 640, 472, 636, 472, 720, 392, 664, 448, 664, 448, 636, 472, 640, 472, 640, 472, 640, 472, 636, 472, 664, 448, 692, 416, 692, 420, 668, 444, 668, 444, 664, 444, 640, 472, 668, 444, 668, 444, 640, 1608, 692, 420, 664, 444, 668, 444, 640, 472, 640, 472, 640, 468, 692, 420, 664, 448, 640, 472, 664, 444, 664, 1588, 664, 444, 668, 1584, 664, 444, 692, 420, 640, 472, 640, 472, 664, 444, 668, 1584, 692, 1556, 664, 1584, 692, 1556, 692, 1560, 692, 416, 668, 444, 668, 1580, 668,};
unsigned int raw23[214]={ 9108, 4416, 664, 1584, 640, 1612, 664, 444, 664, 448, 664, 448, 640, 468, 640, 1612, 664, 1584, 640, 1608, 668, 1584, 636, 1612, 668, 1580, 668, 1584, 664, 1584, 664, 1588, 664, 444, 640, 468, 640, 476, 636, 472, 640, 472, 640, 472, 640, 1608, 668, 1580, 668, 1584, 664, 448, 664, 444, 640, 472, 668, 444, 668, 440, 640, 472, 668, 444, 668, 444, 640, 472, 640, 468, 640, 472, 640, 472, 640, 472, 724, 1524, 664, 448, 640, 472, 640, 468, 640, 472, 640, 472, 640, 472, 720, 392, 636, 472, 640, 472, 640, 472, 640, 472, 640, 468, 640, 472, 720, 392, 640, 472, 640, 1608, 668, 444, 640, 472, 640, 472, 692, 416, 640, 472, 640, 472, 696, 416, 692, 416, 696, 416, 640, 472, 640, 472, 720, 392, 640, 468, 640, 472, 640, 472, 696, 416, 640, 472, 636, 472, 752, 360, 640, 472, 832, 276, 644, 472, 636, 476, 636, 1612, 664, 444, 640, 472, 640, 472, 696, 416, 664, 444, 640, 472, 640, 472, 696, 416, 720, 392, 640, 468, 696, 1556, 664, 448, 640, 1608, 640, 472, 640, 468, 640, 472, 696, 416, 668, 444, 696, 1552, 668, 1584, 664, 1584, 640, 472, 664, 444, 640, 472, 640, 468, 644, 1608, 640,};
unsigned int raw24[209]={ 9108, 1200, 512, 2700, 664, 1584, 640, 1608, 668, 444, 664, 448, 808, 300, 1836, 272, 304, 528, 156, 268, 636, 1612, 664, 1584, 664, 1584, 664, 1584, 640, 472, 640, 468, 640, 472, 780, 332, 808, 1016, 164, 264, 664, 444, 668, 444, 640, 320, 844, 300, 756, 444, 780, 1072, 116, 308, 640, 1612, 664, 1584, 636, 472, 724, 388, 640, 472, 640, 468, 864, 248, 752, 280, 720, 476, 2996, 332, 640, 472, 696, 396, 660, 464, 644, 1612, 664, 444, 640, 472, 640, 472, 640, 472, 636, 472, 640, 472, 724, 388, 640, 472, 640, 472, 2968, 324, 900, 248, 724, 388, 640, 472, 640, 472, 952, 284, 108, 904, 640, 472, 636, 472, 640, 472, 640, 472, 668, 444, 720, 392, 636, 472, 640, 472, 724, 348, 676, 476, 1748, 412, 808, 332, 668, 476, 776, 248, 780, 416, 640, 468, 668, 448, 636, 472, 640, 472, 640, 472, 636, 472, 640, 1612, 664, 444, 668, 444, 640, 472, 888, 208, 656, 332, 776, 472, 640, 472, 724, 344, 680, 472, 696, 420, 636, 1612, 664, 444, 664, 1584, 640, 472, 640, 472, 640, 468, 1752, 472, 640, 1608, 640, 1612, 664, 1584, 640, 1608, 668, 444, 640, 1608, 640, 472, 640, 1612, 636,};
lcd.begin(16, 2); //Start lcd
lcd.setCursor(0,0); //Set in position 0,0
// set the digital pin as output:
pinMode(ledPin, OUTPUT);//Change to output my pins
dht.begin();//Start DHT22 sensor
digitalWrite(ledPin,LOW);//Turn off LED
lcd.print("Tempera:");// print in lcd this word
lcd.setCursor(0,1);//Change cursor position
lcd.print("Humedad:");// print in lcd this word
pinMode(9,OUTPUT); // The library initializes pin 3 as an output
digitalWrite(9, LOW);// Since our LED is connected to pin 9, we initialize it here
unsigned long currentMillis = millis();//time elapsed
if(currentMillis - previousMillis > interval) //Comparison between the elapsed time and the time in which the action is to be executed
previousMillis = currentMillis; //"Last time is now"
h = dht.readHumidity();//humidity value
t = dht.readTemperature();//temperature value centigrades if you want farenheit change to
e = t-2;
//t = dht.readTemperature(true);
//Below is for print data sensors in lcd
lcd.setCursor(9,0);
lcd.print(t);
lcd.setCursor(9,1);
lcd.print(h);
lcd.setCursor(15,0);
lcd.print("C");
lcd.setCursor(15,1);
lcd.print("%");
if (t>=25 && t<=40);
irsend.sendRaw(raw1,210,38);
