ginyp
October 18, 2021, 10:14am
1
Hello, I’m working with TOF10120. The sensor is measuring distance in about max 20 cm. The idea is to build a measuring method like market product Laser Distance Meter that give measurement and stay at that point.
Can anyone give idea to getting closer of that? I tried Averaging and median method of analog read but the result still not meet the requirement.
Post the code and the hardware..
ginyp
October 18, 2021, 3:13pm
4
I'm using Arduino Nano + TOF10120 Sensor for single sensor, but my plan is going to use Nano + TCA9548A + TOF10120 + OLED
This is the code that I found from this reference : ESP32 with TOF10120 Laser Rangefinder distance sensor, IoT water Level Monitoring
#include <SimpleTimer.h>
#include<stdlib.h>
#include <Wire.h>
SimpleTimer timerSensor1;
SimpleTimer timerRef;
int secs1 = 0;
unsigned short lenth_val = 0;
unsigned char i2c_rx_buf[16];
int raw_distance;
int resultDistance;
Wire.begin();
Serial.begin (9600);
timerSensor1.setInterval(200L, func_AVG1);
timerRef.setInterval(1000L, timeRef);
timerSensor1.run();
timerRef.run();
raw_distance = ReadDistance();
Serial.print(F("Distance : "));
Serial.println(raw_distance);
Serial.print(F("Distance AVG : "));
Serial.println(resultDistance);
delay(200);
void func_AVG1()
int x1;
float raw_distanceAVG = 0;
for (int tof1 = 0; tof1 <= 19; tof1++)
x1 = x1 + raw_distance;
raw_distanceAVG = x1 / 20;
x1 = 0;
if ( (raw_distanceAVG < resultDistance) || ( raw_distanceAVG > resultDistance))
if ( secs1 == 4 )
resultDistance = raw_distanceAVG;
if (resultDistance == raw_distanceAVG )
secs1 = 0;
void timeRef()
secs1 = secs1 + 1;
if ( secs1 == 5 )
secs1 = 0;
void SensorRead(unsigned char addr, unsigned char* datbuf, unsigned char cnt)
unsigned short result = 0;
Wire.beginTransmission(0x52);
Wire.write(byte(addr));
Wire.endTransmission();
delay(1);
Wire.requestFrom(0x52, cnt);
if (cnt <= Wire.available()) {
*datbuf++ = Wire.read();
int ReadDistance() {
SensorRead(0x00, i2c_rx_buf, 2);
lenth_val = i2c_rx_buf[0];
lenth_val = lenth_val << 8;
lenth_val |= i2c_rx_buf[1];
delay(100);
return lenth_val;
I tried on a calibration of 100mm and get tolerance about max 12mm of result and still volatile.
What measurement method to get result like market product of Laser Distance Meter that just display a static result of measurement (maybe just stop when reach at avg value) ?
system
Closed
April 16, 2022, 3:13pm
5
